FeFe Posted February 4, 2020 Share Posted February 4, 2020 Have a Peter Wright anvil set on a metal stand. Hard to read the number on it.. but help with identifying is appreciated. My dad had a stroke so helping him clean up the farm . Here are some pics. Thanks to all in advance. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 4, 2020 Share Posted February 4, 2020 What is it that you want to know? It's a standard London Pattern Peter Wright anvil. The weight is stamped across the waist in the CWT system where the leftmost number is times 112 pounds, the middle number is times 28 pounds and can only be 0-3, and the rightmost number(s) is just pounds and can only be 0-27. The actual weight should be within a couple pounds of the stamped weight. (I can't read it from that picture, except for the rightmost: 10; can you tell us what's stamped?) Quote Link to comment Share on other sites More sharing options...
FeFe Posted February 5, 2020 Author Share Posted February 5, 2020 I will try to get the other numbers that are stamped on there, to help ID it better. Mainly want to know the weight of it and the age. Value as well? Thanks for the help ThomasPowers for the info. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 5, 2020 Share Posted February 5, 2020 Value depends a LOT on where it is located; which is not mentioned. Even just in the USA; location can change what it's worth by over a hundred dollars. As IFI is a site on the World Wide Web; we do have people from over 100 different countries participating here---anvils tend to be more expensive in Australia and less expensive in the England for instance. As for weight: unless it's really large; a common bathroom scale will give you the weight if you can't read the CWT stampings. Of course that does require removing it from the stand. Generally stands do not add much value as a user will need a stand the correct height for their body and work style; a beautiful stand the wrong height is just scrap metal to a smith unless they can modify it to fit them. (Which can be more trouble than just building a new stand.) Also if a stand is heavy then it makes it difficult to move the anvil if it's semi-permanently fastened down. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 6, 2020 Share Posted February 6, 2020 Welcome aboard... I always suggest reading this to get the best out of the forum. It is full of tips like editing your profile to show location, how to do a better search plus many others. READ THIS FIRST Because your anvil has England stamped on it, it was imported after 1891 and before 1930 (I could be off on the year) but I'm sure someone will know for sure. Quote Link to comment Share on other sites More sharing options...
fatman928 Posted October 7, 2023 Share Posted October 7, 2023 On 2/5/2020 at 6:09 PM, Irondragon Forge ClayWorks said: Welcome aboard... I always suggest reading this to get the best out of the forum. It is full of tips like editing your profile to show location, how to do a better search plus many others. READ THIS FIRST Because your anvil has England stamped on it, it was imported after 1891 and before 1930 (I could be off on the year) but I'm sure someone will know for sure. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted October 7, 2023 Share Posted October 7, 2023 Did you have a question or comment about my post or Peter Wright anvils? Quote Link to comment Share on other sites More sharing options...
