JHCC Posted January 25, 2020 Share Posted January 25, 2020 I recently salvaged a large fuse box panel assembly and took the pieces to the scrap yard. The copper busbars got turned into cash, partly because I needed the cash, but also because I didn't want to take the risk that they were beryllium copper and therefore not good for me to work. However, the copper bars that connected three of the boxes to the busbars are a nice size (about 3/16" x 1/2"). I'm wondering if there's any way to determine whether or not they are beryllium copper, just to set my mind at ease. (Unfortunately, my usual scrap yard has closed, and I therefore couldn't use their XRF gun to identify the alloy.) Quote Link to comment Share on other sites More sharing options...
Hans Richter Posted January 25, 2020 Share Posted January 25, 2020 DearJHCC, to take away some worries and a short explanation. As you can see on the pictures, it is about busbars from a discarded control cabinet. These are usually made from low-alloyed or pure copper. Here there are only traces of some alloying elements such as nickel, cobalt aluminum and sometimes Beryllium (0.4%). With real Berilyum copper there is> / = 3% Beryllium which is used in spark-free tools, is very expensive and actually very dangerous for your health when machining or forging. See the Wiki link. At the start of my foundry activities I myself made my own bronze of 9 parts of busbar and 1 part of tin. https://en.wikipedia.org/wiki/Beryllium_copper 2.1285 Becopper.pdf Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted January 25, 2020 Share Posted January 25, 2020 BeCu alloys look like brass, no copper red unless heat treated, then there is some, but it rubs off. When polished it looks just like gold. We had to be careful as our chem dip would leave the parts looking gold plated, and one customer almost sent some out thinking they had already been plated. We machined literal tons of it at the last shop. The Buss bars were copper, as that is not a good application for BeCu alloy properties. BeCu is a chronic inhalation hazard, so fumes or dust is an issue. I talked with our supplier and the Be content was a max of 2%. Quote Link to comment Share on other sites More sharing options...
JHCC Posted January 26, 2020 Author Share Posted January 26, 2020 Sounds good; thanks, guys. Quote Link to comment Share on other sites More sharing options...
