Binesman Posted January 3, 2020 Share Posted January 3, 2020 I don't want to say to much without first speaking with the admin of the site. However I'd like to hear from you guys if you think these prices are fair. 2x2x9 chamber for 175 4x4x9 chamber for 225 and a 8x4x9 chamber for 250. All 3 capable of reaching forge welding, all of them come with everything needed (burner/shell/regulater) but they do need assembled (takes about an hour) Do you guys believe those are fair prices (and I know everyone here tends to build there own but think back to before you knew how to) Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 3, 2020 Share Posted January 3, 2020 Need more details; what/how much insulation? (If fiberous is it sealed?) What is the shell made from? Construction? Is the interior flux resistant---if you plan to weld in it. (And how resistant if you plan to weld a lot in it...) And before I knew how nobody was selling propane forges; so I went to 2 forge building workshops put on by an ABANA affiliate and built NA and FA forges. Quote Link to comment Share on other sites More sharing options...
Binesman Posted January 3, 2020 Author Share Posted January 3, 2020 Trying to get away from kaowool. Cant see it being to long before its banned here like in EU. Construction is 4/6/8 k28 firebricks bonded together using a 3k furnace cement. Chamber will be matrikote coated (a pint goes with each kit so enough for some repairs as well.) the shell will be removable to change bricks out and make repairs as they become necessary. It will be 2 U shaped 20gauge pieces of sheet metal that will slide together to create the shell. Held in place by a piece of angle iron running all 4 edges tightened on both x and y access. Na 1/2" 2x2x9 and a 3/4" on the two larger forges. 0-20 psi regulator and 4 ft hose included. Standard brick size 4.5x2.5x9 Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted January 3, 2020 Share Posted January 3, 2020 As long as you don't post commercial links, you can mention the name's/manufacture of the forges you are interested in. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 3, 2020 Share Posted January 3, 2020 Actually I wondered if he was thinking of selling them. Quote Link to comment Share on other sites More sharing options...
Binesman Posted January 4, 2020 Author Share Posted January 4, 2020 You are on the nose Thomas. I'm looking in to setting up a forge kit business. Was looking for advice on my pricing. Did not want to mention to much in to it because I'm not trying to push for sales im looking for opinions and advice from respected peers. Quote Link to comment Share on other sites More sharing options...
MCalvert Posted January 9, 2020 Share Posted January 9, 2020 Are you going to do this as a hobby, for supplementary income, or try to make a good living? Quote Link to comment Share on other sites More sharing options...
Binesman Posted January 22, 2020 Author Share Posted January 22, 2020 hobby. I find as I look at todays forges. I can't get one for under 500 or so that I would call "quality". So I figure I can keep the supplies for a "kit" in my garage box it up and ship it out on my way to work. That's why they aren't built forges as well. Okay the fact that I think everyone should build there own forge so they have an idea of how to maintain it is also part of the "kit" reasoning. Quote Link to comment Share on other sites More sharing options...
MCalvert Posted January 22, 2020 Share Posted January 22, 2020 In my opinion, the more people that get involved in metal-working the better, so I hope you are very successful if you start doing this. I would think of some way to ship with a safety brief type document, and point troubleshooting to IFI.. maybe that will offer a good starting point? Quote Link to comment Share on other sites More sharing options...
Binesman Posted January 22, 2020 Author Share Posted January 22, 2020 my plan is to start a youtube channel. It may not have many video's but there will be one going over the different types of forge builds wool/brick/refractory and any combination there of. Along with general safety concerns. I will probably preach a little about blanket and ridgidizer because that's kind of a personal kick. but yes I already and will continue to direct people here. IFI is probably the greatest resource I have found to date. Quote Link to comment Share on other sites More sharing options...
Jealdi Posted August 3, 2020 Share Posted August 3, 2020 Binesman, Did you ever get this off the ground? Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted August 3, 2020 Share Posted August 3, 2020 Your prices may be good; or not, depending on on how well your forges work. Provide photos of the forge at work, and you will get better answers. And no; achieving welding temperature is only a partial indication. Without a good look at the forge exhaust; it is insufficient. Quote Link to comment Share on other sites More sharing options...
