iwfabrication Posted November 25, 2019 Share Posted November 25, 2019 Just finished my double burner and the flame doesn't look like others I've seen. Here's a link to the video. Burners have 1" reducer on flame end, 1.5 on intake side. .025 mig tip for gas outlet. Running at about 2-3psi for gas. Aair intake has rotating covers to change air intake. https://youtu.be/uc-ohbttq_M Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted November 26, 2019 Share Posted November 26, 2019 Your video is about Sportster fly wheel bearings???? Have you read this yet? READ THIS FIRST It will help you get the best out of the forum with tips like editing your profile to show your location. Quote Link to comment Share on other sites More sharing options...
iwfabrication Posted December 16, 2019 Author Share Posted December 16, 2019 Just got back to looking at this. Somehow copied the wrong YouTube link. Will edit Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 16, 2019 Share Posted December 16, 2019 We still have no idea where in the world you are located and the 15 second video doesn't tell us much. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 17, 2019 Share Posted December 17, 2019 It does tell us that bother burners have very weak and heavily reducing flames; which tend to go together. So, no it's time to see the rest of the burner, and maybe you'll need to answer our questions about it; but only if you want satisfactory answers. Quote Link to comment Share on other sites More sharing options...
Matt Matt Posted December 17, 2019 Share Posted December 17, 2019 iwfabrication don’t stop you’re testing and trials. Are you running LP or NG? I am somewhat guessing liquid propane. Get a regulator that can jump you up to 15 psi. And keep everything else the same. Then report back. Most of the time most guys here are helpful. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted December 25, 2019 Share Posted December 25, 2019 Merry Christmas to all Quote Link to comment Share on other sites More sharing options...
iwfabrication Posted February 19, 2020 Author Share Posted February 19, 2020 Been a minute! I'm located in the USA in Michigan. But I'm back to getting the forge setup. While in the forge my flames is greenish, which would indicate lean. One burner will reach blue flame, the other burns out before reaching blue - too much air. Running at about 5 psi currently. At this setting a piece of rectangular stock 10"*1"*1/4" gets red at about 5min. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 20, 2020 Share Posted February 20, 2020 We won't remember this once leaving this post, hence the suggestion to edit your profile to show it. Have you read this yet? READ THIS FIRST What burner plans did you follow? Pictures of them will help. What regulator are they hooked up to? Quote Link to comment Share on other sites More sharing options...
Binesman Posted February 21, 2020 Share Posted February 21, 2020 green flame is RICH not lean. you are not getting enough oxygen. are you using a mig tip and if so what size. or did you drill your hole and what size? how long is your mix tube? Quote Link to comment Share on other sites More sharing options...
