Gavj75 Posted October 11, 2019 Share Posted October 11, 2019 Hello again to all. My latest project is a tyre hammer and so far, I think my build is coming on quite well but again, I'm not to sure about something. So my first question is this:- is it down to personal preference for how much vertical travel the hammer has or are there any kind of parameters to go by? My hammer is around 45lb and I was thinking around 6 inches. Any advice? Second question:- I was going to set my hammer up so that it's just touchin the anvil when it's at it's lowest point in a stationary position therefore, the flex on the spring when it's in motion will give the hammer it's power.I was going to put some shims under the anvil so I have some adjustability. Am I going about this the right way as this is all guess work on my part or is there a better way to do it? Any advice will be much appreciated, thanks Gav Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 11, 2019 Share Posted October 11, 2019 Please give more info on the size of stock you want to work in general and also possible outliers. Quote Link to comment Share on other sites More sharing options...
arftist Posted October 12, 2019 Share Posted October 12, 2019 3.5 inch crank offsett for a 7" stroke. An inch of free space between the dies is good minimum but you should have enough adjustment for tools as well. Quote Link to comment Share on other sites More sharing options...
Gavj75 Posted October 13, 2019 Author Share Posted October 13, 2019 Thanks for the info guys. The kind of stock I'll be working will be probably no thicker than 40mm. I plan to make Damascus blades however I'm quite a creative chap so who knows what my forging future holds? As for the 'outliers', I'm not sure what you mean by this term? Can you explain please? Thanx, Gav Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 14, 2019 Share Posted October 14, 2019 Lets say you generally, 80%+, forge stuff below 1" round; but on a semi regular basis you make andirons from RR rail. The RR rail would be an outlier that should be allowed for. Quote Link to comment Share on other sites More sharing options...
