Goods Posted September 29, 2019 Share Posted September 29, 2019 I’m looking at trying my hand at making a couple of tomahawks. I’m planning to use A36 with a 5160 bit. I was thinking about using 1/8” x 1” bar stock for the body, but now I’m afraid that may be too thin. Anyone have any recommendations? Thanks! David Quote Link to comment Share on other sites More sharing options...
arkie Posted September 29, 2019 Share Posted September 29, 2019 Too thin. Use 1/4" thick bar, 1" or wider, depending on the blade size. Quote Link to comment Share on other sites More sharing options...
anvil Posted September 29, 2019 Share Posted September 29, 2019 For what it's worth, 1/8"x1" is called flat stock Quote Link to comment Share on other sites More sharing options...
dickb Posted September 29, 2019 Share Posted September 29, 2019 (edited) 1/8 stock is much too thin. You will always lose some thickness to scale and to forge welding. 1/4 or 3/8 would be better Edited September 29, 2019 by dickb Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted October 5, 2019 Share Posted October 5, 2019 1/4"X1" is about right for wrapped eye. From there you can change the eye into different models. this hawk is made from 1/4" X 1 and you can see the difference in the pole and in the blade edge shape. The 2nd photo shows a straight wrapped eye and then a longer pole type as well. All 1/4X1" Quote Link to comment Share on other sites More sharing options...
HP500 Posted October 25, 2019 Share Posted October 25, 2019 I've been using 1.5" x 1/4" x 10.5 long mild steel and forge welding in a piece of 5160 for the bit. It works for me. Quote Link to comment Share on other sites More sharing options...
Goods Posted October 25, 2019 Author Share Posted October 25, 2019 Thanks, that’s almost exactly the same size that worked out for me. I tried about 2” longer for two hawks, but the proportions came out all wrong. Quote Link to comment Share on other sites More sharing options...
will52100 Posted January 19, 2020 Share Posted January 19, 2020 I generally use 1 1/4" x 1/4" x 12" 1018 for most of my hawks. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted January 28, 2020 Share Posted January 28, 2020 1" was traditional for a lot of trading hawks.. I like 1.25 to 1.5" depending on what I want to do with the wrap. Quote Link to comment Share on other sites More sharing options...
