Mr Moose Posted September 4, 2019 Share Posted September 4, 2019 Can always tell a fellow shooter by the accronyms that they think of first. Quote Link to comment Share on other sites More sharing options...
Chris C Posted September 4, 2019 Share Posted September 4, 2019 Amen. Quote Link to comment Share on other sites More sharing options...
JHCC Posted September 4, 2019 Share Posted September 4, 2019 Academia and artillery are similar in that (A) they both involve intentional infliction of maximum damage on one's enemies and (B) degrees are extremely important. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted September 4, 2019 Author Share Posted September 4, 2019 JHCC auto correct can be a fickle beast. Quote Link to comment Share on other sites More sharing options...
JHCC Posted September 4, 2019 Share Posted September 4, 2019 You're telling me. I was typing "question" this morning, and it autocorrected to "quesadilla". Quote Link to comment Share on other sites More sharing options...
Les L Posted September 4, 2019 Share Posted September 4, 2019 That's not a bad auto correct, makes you think about lunch. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted September 4, 2019 Share Posted September 4, 2019 Jennifer, Just curious here. I believe you have adjustable jacks at the 4 corners of your trailer. If the anvil stand rests on the ground why couldn't you adjust the height of the trailer with the jacks to end up with your preferred anvil height? On second thought while I'm typing this I'm guessing with all that weight the wheels still need to take some of the weight to keep the whole thing from bowing in the middle. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted September 4, 2019 Author Share Posted September 4, 2019 You can certainly change the anvil height via the Jack's and is what I do for fine tuning. There are actually 2 problems with this and when i designed the trailer front viewing doors in particular were designed to have a particular height. (Bottom height or threshold for the viewing area). If the trailer as a whole gets to high, so I can change (shorten) the floor to anvil height. It also changes the view outside height (whole trailer moves up) The wall moves that much higher up. 2 inches is a lot for kids. 2nd, the adjust time to level the trailer and get the correct anvil height. I designed the stand originally to be a little taller incase I went somewhere that there was a pit or dip in the landscape. Since the trailer was built and nearly 40 demonstrations later I have never had the pit problem. I have had the anvil sit 2 inches taller though.. So since this is the case and I am modifying stands anyhow I figured why not kill 2 birds with 1 stone. Now instead of having to level the trailer based solely on anvil height, I will be able to park, drop the anvil and just kiss the ground with the Jack's. This will speed up the setup process. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted September 5, 2019 Author Share Posted September 5, 2019 6 hours ago, Buzzkill said: On second thought while I'm typing this I'm guessing with all that weight the wheels still need to take some of the weight to keep the whole thing from bowing in the middle. I double framed the trailer and engineered it so it won't sag or bow in the middle even with axles completely off the ground. the frame is solid enough that it does not budge anywhere. I can lift the whole trailer off the ground with just the tongue and one rear jack. I usually walk around adjusting the jacks so they all have the same tension on the jack handle. I have a mandrel making video I finished but it's long as I upset 7/8" round into 1.250" sq then forged it back down into the mandrel. I think it's a good video but most would argue why do that amount of work.. My argument as always is" Because I can". when in reality it was the stock on hand on hand and well, I can. It shows the floor moving where the camera is mounted way up on the wall. I have since purchased some 1.250" sq which is the starting size tapered out and then made. Of course, the whole thing is not using a swage block. and this video shows how to create the ridge in the middle without the use of a swage block or form. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted September 5, 2019 Share Posted September 5, 2019 Makes sense. I hadn't thought about the viewing angle. Thanks for the explanation. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted September 5, 2019 Author Share Posted September 5, 2019 my pleasure. It's great you figured out the trailer and anvil height. Many have a hard time understanding the different concepts or separation of the anvil being on the ground.. Great question really appreciate it. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted September 7, 2019 Author Share Posted September 7, 2019 I today cut a piece of between wood for the Refflinghaus stand and then proceeded to make the hold down bolts. I measured 5 times and while the length is supposed to be right they are to short as there is a funky jog on the upsetting block side (its all trial and error kind of thing)... I will have to cut them in half and make 2 new ends on longer shafts to make up the 1" needed to get them where they go. 5/8" cross bars with 3/4" bolt sections. Quote Link to comment Share on other sites More sharing options...
nga Posted September 17, 2019 Share Posted September 17, 2019 Sorry talk about other subject. Could you please advise where i can buy 500bl Habermann as photo below On 8/19/2019 at 10:15 PM, yesteryearforge said: I think You will love the Refflinghaus Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted September 17, 2019 Author Share Posted September 17, 2019 Nga, I'm not sure. I have wanted to purchase a 500lbs Haberman myself but never had any luck with the purchase. I did contact them to see about importing one and logistics were not in my favor. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted September 17, 2019 Share Posted September 17, 2019 Welcome nga... it would help to know where in the world you are located, hence the suggestion to edit your profile to show location. This thread will explain. READ THIS FIRST Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted September 21, 2019 Author Share Posted September 21, 2019 Ok, stand is done, bolts are done. side trays are done as is the hardie tool holder. I made 2 sets. there is a photo of the rejects. I made them, undersized in the eyes on the first 2 and then to short on the second 2. Set number 3 were good. Was good practice anyhow. Quote Link to comment Share on other sites More sharing options...
1forgeur Posted September 21, 2019 Share Posted September 21, 2019 Lookin good! Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted September 21, 2019 Author Share Posted September 21, 2019 thanks. Of course after the fact I have all ready came up with a better way to do it. LOL. By putting a cross through the center of the stand i could have created the same movement of the trays but had the outside with less obstructions of the center. I like to store wire brushes in the center of the stand so they are handy. By moving the bottom inside pivots to the center it would open the area up and would have made fabrication and installation easier. Any how it's the learning curve. Quote Link to comment Share on other sites More sharing options...
Les L Posted September 21, 2019 Share Posted September 21, 2019 Jennifer, you’re fabrication skills are as amazing as your blacksmith skills. You never stop thinking outside of the box on how to improve problems you have just solved and always share them to help everyone else improve their skills and how their equipment is set up to improve efficiency. I’ve just started in blacksmithing, but have been involved in metal fabrication for almost 50 yrs, but I learn something new from all of your posts, and most of the other people that post here. I thank all of the great people on IFI for taking time out of their lives to help and support everyone on this forum. Quote Link to comment Share on other sites More sharing options...
1forgeur Posted September 22, 2019 Share Posted September 22, 2019 I have a feeling you will be building more stands! Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted September 22, 2019 Author Share Posted September 22, 2019 oooh, you are tricky.. yes 4 more to make.. Will be fully adjustable height wise using blocks of wood or steel and still hold the anvil securely down to the stand. Still working on a quick release system that will offer the pressure I want for the hold downs but quick and easy. one screw mounted underneath perhaps with a hand wheel. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted September 22, 2019 Author Share Posted September 22, 2019 Les L. Those are very kind words and thanks so much for sharing them. Feedback to me is one of the most important aspects of any contribution. I try my best to give honest information based on what I have learned. I'm thankful people can find the information useful and can help them along on their journey. Even if it's contrary to what others are understanding. The resources here on IFI are pretty amazing. It's the only blacksmithing centered forum I go to. Quote Link to comment Share on other sites More sharing options...
arkie Posted September 22, 2019 Share Posted September 22, 2019 Jennifer, you are so creative! No store bought chineesium hold-down bolts for you. Your skills always amaze. I really like the swing out tool racks, too. When you start teaching in your new shop, your students will probably have no clue as to the skills of their teacher...wish I were closer to be able to experience that. Quote Link to comment Share on other sites More sharing options...
Chris C Posted September 22, 2019 Share Posted September 22, 2019 Amen to that, Arkie. Wish I were closer also. 24 hour driving time is way beyond an old feller like myself. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted April 9, 2020 Author Share Posted April 9, 2020 Quote Link to comment Share on other sites More sharing options...
