Three-burner gas forge recommendations
GMoore
Those are the only long 3 burner forges I know of in regular use making knives. A finalist rarely has larger than a 2 burner forge at home.  Occasionally you see guys line a couple up to heat treat or use a vertical heat treat forge but they don't forge out of them.
If you heat more than you can work it really degrades the steel and scale losses mount up.
The four forges at ESSA are three burner monsters. They were designed by a local smith so students could work out of both ends without crowding with each others stock. They are gas hogs to say the least but ESSA has a 1000 gallon propane tank to feed them so life is good.
