J.P. Hall Posted July 18, 2019 Share Posted July 18, 2019 I came across this post from Dan Prendergast about "glazing wheels": https://www.instagram.com/p/B0Bpd0ZHucl/ In his words, Quote Glazing wheels- an old school, low waste alternative to belt abrasives. Hide glue and the abrasive of your choice on the wheel of your choice. They have their limitations, but work through the grits, finish off with a good grease less finishing compound or one of those brillo bobs, and you get a pretty good working finish, I think. I tried researching the term, and I did find a greaseless finishing compound that is abrasive grain suspended in hide glue, to be used like buffing rouge. Does anybody have experience with this? I'd be interested in trying it out, I'd probably want some sort of guard around the wheel though. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted July 18, 2019 Share Posted July 18, 2019 I have a set of them about a half inch wide. Good for sharpening but with the grit (embedded in Elmer's Glue) I have they don't remove much metal and a 2X72 is better. Quote Link to comment Share on other sites More sharing options...
basher Posted July 19, 2019 Share Posted July 19, 2019 I am interested in trying one. . I have used the greaseless finishing compound and did not find it useful...However it should be noted that the people I now who use these are generally making soft clad blades (san Mai) and only usint these to finiah..and I think there is a world of difference when grinding these blades as opposed to full carbon steel. with my bladesmithing school I get through 1000+ belts a year ...I would love a more eco or economic alternative! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 19, 2019 Share Posted July 19, 2019 Do you make sure that the forged blades are scale free to start? Scale eats belts. The sword maker I worked for used to sandblast the blades to remove scale before starting to grind. Quote Link to comment Share on other sites More sharing options...
