Shared argon tank
GMoore
!Take this with a grain of salt as I'm not a "professional" welder.!  Generally the hoses for inert welding gas could be spliced since many times I have seen them with generic hose clamps. I don't see why you couldnt splice a Y connector into the line.
Are you mainly welding stainless with the mig (which would take straight argon)? When welding steel with the mig generally you want an argon75%/co2 25% mix. While tig generally uses straight argon.  Again tho, there are different preffered gasses for different materials and setups. Just curious.
  • 2 weeks later...
