Maushart Posted July 11, 2019 Share Posted July 11, 2019 Hello everybody. I want to forge a bell ( about 18 to 20 cm big). I want to Use it for cattle. I want to make the sound last longer when it strikes. Do i have to harden it more or do i need more tension on the metall? Or do i need to do something else to make it sound longer? Regards and thanks in advance Sebas Link to comment Share on other sites More sharing options...
pnut Posted July 11, 2019 Share Posted July 11, 2019 (edited) Most bells that have a long sustain are cast. If you're talking about a plain cowbell they are made from folded sheet and just kinda make a clunk noise like hitting a tin can. Bell making is fairly specialized. You may just have to experiment.I'd try thicker stock first. If you're trying to make a bell to call them to the barn you could probably have better luck with a triangle. Pnut Edited July 11, 2019 by pnut Link to comment Share on other sites More sharing options...
Glenn Posted July 11, 2019 Share Posted July 11, 2019 Bell or a device to generate a sound they will come to recognize as "dinner is served"? At what distance does it need to be heard? This is where your location is important as terrain and weather conditions make a difference. Link to comment Share on other sites More sharing options...
Daswulf Posted July 11, 2019 Share Posted July 11, 2019 I've made a few triangle dinner bells and have found they seem to ring better when using a hardenable steel and hardening them. I haven't used much of a higher carbon steel than around 60pts. You could also make a large bell/gong out of an old air gas cylinder tank. Link to comment Share on other sites More sharing options...
JHCC Posted July 11, 2019 Share Posted July 11, 2019 Welcome to IFI! If you haven't yet, please READ THIS FIRST!!! Link to comment Share on other sites More sharing options...
Maushart Posted July 11, 2019 Author Share Posted July 11, 2019 The bells look like below. And i exactly dont want them to sound like cans, so that would be my question. I know that i can experiment with the shape, but i was wondering, whether i can do something as well with treating the metal in some specific way. And those bells are made fot the cows to wear them and to be heard. Regards Link to comment Share on other sites More sharing options...
Buzzkill Posted July 11, 2019 Share Posted July 11, 2019 We had one of those when I was a kid. My dad brought it back with him from Switzerland. Mom used it to call us to lunch and dinner rather than the cows. My recollection is that it was fairly loud and did ring rather than "clunk" but it did not have a long sustain. I'd say with normal to slightly elevated ambient noise levels and relatively flat terrain you can easily hear it a half mile away and probably further if it's being shaken vigorously. Link to comment Share on other sites More sharing options...
JHCC Posted July 11, 2019 Share Posted July 11, 2019 Keep in mind that the purpose of bells on cattle is twofold: so that the cowherd can keep tabs on them, but more importantly because it makes the herd stick together. As such, they're not really designed to have sounds that carry huge distances, like a church bell. In sheep herding, it was common for a bell to be put on a wether (a castrated male sheep) so that the rest of the herd would follow the sound; this is where we get the expression "bellwether". Link to comment Share on other sites More sharing options...
Latticino Posted July 11, 2019 Share Posted July 11, 2019 It had to be said... Link to comment Share on other sites More sharing options...
yesteryearforge Posted July 11, 2019 Share Posted July 11, 2019 Link to comment Share on other sites More sharing options...
Steven NY Posted July 11, 2019 Share Posted July 11, 2019 The bells I use for falconry are definitely hardened and for their size ring very loud, they are made by Dave Noble. Bells will crack after being worn by a hawk for a season or two from their continued work hardening. I have made small bells for my birds, but they where never as loud as the Noble bells. I would put them on my dogs collars for a few weeks to work harden the brass, and that would always help with their tone. Keep in mind when making the clacker in a bell it should be faceted not round. This makes it tinkle more, although it may not be an issue with a square bell. For small table bells made of steel I usually harden them. But even these ring better the more they are rung. The thickness of the metal is also important thicker bells like I have made usually have a duller sound or lower pitch. How they are attached to the cow will also make a difference, if the bell is resting against the animal it will deaden the ring. Like grabbing a cymbal after it is struck. Not sure but hope these ramblings help, W Link to comment Share on other sites More sharing options...
Frosty Posted July 11, 2019 Share Posted July 11, 2019 A cow bell isn't going to have a long sustain as it's touching the cow which will damp the resonance. Typical cow bells as I recall are folded and not cupped. Being folded will damp resonace as the sound waves have to turn sharp corners and there are different lengths of metal on the other sides. This effect is why large bridges always have a skew, each girder is a different length so a resonant wave can't form. See Tacoma Narrows or Galloping Gerty bridge collapse for what happens when a resonant wave is in a self reinforcing cycle. If you want any sustain the bell needs to be a cup shape, round is best. Flared or tulip shape is easier to tune for tone. If you wish to forge bells I'd suggest you look into sinking and raising bronze. However if you wanted to learn metal spinning and can get a friend to hold torch for you spun bronze makes excellent bells. Dad cranked out hundreds if not thouands. I used to turn an ugly gray blueish green from polishing the things, 100 grt emery cloth and diesel oil to remove tool marks. Oh, I held torch too, bronze was trickier than jet/rocket alloys. When we were done they went to the heat treater then to the tuner. Each was individually tuned but sounded great. Dad had a couple as souverniers, I wonder if my sister still has them. hmmmm. Frosty The Lucky. Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 11, 2019 Share Posted July 11, 2019 Typical cowbells in the United States of America are folded. Elsewhere in the world they are not. Some of the ones I remember from Switzerland were cast. Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted July 12, 2019 Share Posted July 12, 2019 The one my Dad brought back from Switzerland in the 50's was cast brass and pretty ornate. It also had more of a standard flared lip bell shape the rounded ones like in the post above. We actually have at least one person on here that works(ed) at a bell foundry in England. As mentioned before, compressed gas cylinders make excellent gongs, and have good sustain. I have a large weld on pipe cap that is around 3/8" thick and 14" in diameter set on a post that has a nice ring to it. Some others that I found with good rings are automatic transmission clutch housings and aluminum car wheels. Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 12, 2019 Share Posted July 12, 2019 I use valve stem protector caps from welding tanks as wind bells. Link to comment Share on other sites More sharing options...
Maushart Posted July 12, 2019 Author Share Posted July 12, 2019 Thx for all the good answers! Link to comment Share on other sites More sharing options...
pnut Posted July 13, 2019 Share Posted July 13, 2019 The book "Foxfire 5" has instructions for making cowbells on pages 175-180. They are the box type cowbells not Alpine cowbells like pictured above but still may have some useful info. Pnut Link to comment Share on other sites More sharing options...
wpearson Posted July 13, 2019 Share Posted July 13, 2019 Link to comment Share on other sites More sharing options...
rockstar.esq Posted July 17, 2019 Share Posted July 17, 2019 pnut, I have that book too! I was going to mention that the gent in that passage liked to use salvaged steel from washing machines because medium carbon steel had a brighter tone. Link to comment Share on other sites More sharing options...
JHCC Posted July 18, 2019 Share Posted July 18, 2019 On 7/11/2019 at 3:55 PM, Frosty said: A cow bell isn't going to have a long sustain as it's touching the cow which will damp the resonance. Generally, they hang freely from the collar, and therefore aren't being dampened by contact with the cow. Here's an episode of the TV show "How It's Made" showing how Swiss cowbells are made: Note that they mention hammering the entire surface, to work-harden the bell and improve the sound. Link to comment Share on other sites More sharing options...
Frosty Posted July 18, 2019 Share Posted July 18, 2019 Swiss cows must have strong necks. The last footage shows the bell against the cow's neck, so much for my understanding of damping resonance. Thanks for the link John, I LOVE, "How it's made." Frosty The Lucky. Link to comment Share on other sites More sharing options...
Daswulf Posted July 18, 2019 Share Posted July 18, 2019 That's a big cowbell! Link to comment Share on other sites More sharing options...
JHCC Posted July 18, 2019 Share Posted July 18, 2019 The point of suspension is against the cow's neck, but that's not where the bell is resonating; that happens at the lip. 6 minutes ago, Daswulf said: That's a big cowbell! Keep that in mind the next time you ask for More Cowbell! Link to comment Share on other sites More sharing options...
bigfootnampa Posted July 18, 2019 Share Posted July 18, 2019 Please keep in mind that the cow wearing the bell will have to live with it’s sounds at close range... ALL DAY... EVERYDAY! Excessive loudness and sustain are NOT desirable... from a cow’s point of view! Link to comment Share on other sites More sharing options...
rockstar.esq Posted July 18, 2019 Share Posted July 18, 2019 The tone on that thing reminded me of a metal garbage can. I can't imagine listening to that racket all day, every day. Link to comment Share on other sites More sharing options...
Please sign in to comment
