Donal Harris Posted June 29, 2019 Share Posted June 29, 2019 Supposedly it is frozen and the screw will not turn, but for $20 it seems worth the risk. It should be wrought iron. I could use that even if I can’t get it working again. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 29, 2019 Share Posted June 29, 2019 Soak it in a bucket of ATF and acetone. Pull it every day or so and try working the screw, don't force it, just bump it back and forth. it'll loosen the screw. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
caotropheus Posted June 29, 2019 Share Posted June 29, 2019 It is impossible to go wrong for 20 USD for that vice even with a frozen screw. You can forge the spring and fabricate the mounting plate later. Listen to Frosty, apply his method and the screw will become loose one day. Patience is key here, do not force anything or overheat there are brazed parts in the screw area that may become loose or destroyed... Don't forget to show us the vice after restoration and in operation. Quote Link to comment Share on other sites More sharing options...
Glenn Posted June 29, 2019 Share Posted June 29, 2019 It took a long time to freeze up, so do not get excited about taking it a while to work loose. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 29, 2019 Share Posted June 29, 2019 I'd be all over it at $20 like others have said soaking it in a 50/50 mix of trans fluid & acetone will get it going. Also soak the pivot point of the moveable jaw it's probably frozen too. It will be easy to make an extension for the leg that someone cut off, they must have had it mounted low to do some heavy striking on it. Quote Link to comment Share on other sites More sharing options...
anvil Posted June 29, 2019 Share Posted June 29, 2019 is it home yet? and a third vote for an atf/acetone soak Quote Link to comment Share on other sites More sharing options...
Donal Harris Posted June 29, 2019 Author Share Posted June 29, 2019 Someone was faster. I missed out on a rivet forge with blower for $45 a month ago as well. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 30, 2019 Share Posted June 30, 2019 I've snoozed good deals my whole life. Not all of them but more than I wish I had. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
lazyassforge Posted June 30, 2019 Share Posted June 30, 2019 Frosty, An wise old man told me “it’s not the good deals you miss that hurt you, it’s the bad deals you get that hurt you” Bill D Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 30, 2019 Share Posted June 30, 2019 True words. A bad deal can be like a social disease. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
