killbox21 Posted June 28, 2019 Share Posted June 28, 2019 I just traded an Alaskan ulu I made for this old 2 burner forge. She said her husband was a farrier before he died if that helps. I fixed some leaks and a stuck valve. It fired right up. Quote Link to comment Share on other sites More sharing options...
Chris C Posted June 28, 2019 Share Posted June 28, 2019 Good for you....................good trade, I'd say. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 28, 2019 Share Posted June 28, 2019 It looks like an early Forgemaster or Hypona forge to me. One of our Farriers will probably have more ideas. Quote Link to comment Share on other sites More sharing options...
killbox21 Posted June 28, 2019 Author Share Posted June 28, 2019 I cleaned it up a little. I don't see any markings anywhere. It has been well used from the looks of it. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 28, 2019 Share Posted June 28, 2019 I believe Forgemaster is a good call. A friend of mine has been using one for probable 35+ years, shoing horses and general blacksmithing. Good forges. Typically he gets it hot then shuts off one burner for general forging and demos. Good score. Nice looking ulu. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
killbox21 Posted June 28, 2019 Author Share Posted June 28, 2019 Thanks everyone. I also found a valley brand forge that looks similar, except that it has a door on the back. I did find another leak right where it goes into the tank, so I won't be able to see what it's really got until I replace that. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 30, 2019 Share Posted June 30, 2019 Replace the O ring on the tank fitting and take a good look at it. People tend to over tighten them and they get distorted, especially if they don't wipe them off first. Is it the hose or regulator that's leaking? Believe it or not replacing the regulator is cheaper than the hose. Nice forge, good score. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted July 1, 2019 Share Posted July 1, 2019 The other thing I would do is reroute the hose between the burners to behind the legs or make a sheet metal shield to protect the hose from dropped hot steel. Hot steel & rubber hose don't play well together. Quote Link to comment Share on other sites More sharing options...
killbox21 Posted July 1, 2019 Author Share Posted July 1, 2019 Good idea on the hose rerouting. Thanks. I may replace all these hoses,it all looks old. Quote Link to comment Share on other sites More sharing options...
Steve Shimanek Posted July 1, 2019 Share Posted July 1, 2019 Pretty sure Valley Forge is the right call; my mentor uses those as he knows the owner. The burner tube is a good identification aspect. Quote Link to comment Share on other sites More sharing options...
killbox21 Posted July 1, 2019 Author Share Posted July 1, 2019 While I wait on a new regulator to arrive. I decided to clean it up some. Quote Link to comment Share on other sites More sharing options...
Chris C Posted July 1, 2019 Share Posted July 1, 2019 Looks good. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted July 1, 2019 Share Posted July 1, 2019 18 hours ago, Steve Shimanek said: Pretty sure Valley Forge is the right call; I believe you are right, just looked up that one and the picture is identical. Good call. Quote Link to comment Share on other sites More sharing options...
killbox21 Posted July 5, 2019 Author Share Posted July 5, 2019 Since no place around here had a 9/16 fitting for the needle valve, I had the auto parts guy make me up a hydraulic line and got it going. No leaks, let it run about 15 minutes wide open. Any downside to this? He said the hose was rated for 5100 psi. So I don't see that being an issue. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted July 5, 2019 Share Posted July 5, 2019 The forge is high orange with its whole front side wide open, which means it will reach lemon yellow once you put a baffle wall in front of it; probably high yellow with an emissive coating. Looks like you have a very nice forge there Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted July 5, 2019 Share Posted July 5, 2019 The only thing I see is the hydraulic hose. If it isn't rated for propane it may deteriorate. Not sure about that, but regular air hose is bad with propane, with high pressure hydraulic hose you may be OK just keep an eye on it. Quote Link to comment Share on other sites More sharing options...
