Peppie Posted June 2, 2019 Share Posted June 2, 2019 Was wondering if I could fit a semi- well tooled forge in a small space... so far so good. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 2, 2019 Share Posted June 2, 2019 I could work there easily, the only change I'd make is to put the anvil on a mobile stand but that'd be a factor of my style of working. I move my anvil's orientation to the fire frequently, I don't like having that BIG IR floodlight of a forge at my back when I'm at the anvil. I try to keep it aimed 90* away. Your forge is more closed than my current one and my next one won't have the same issues. My thoughts on keeping the anvil mobile may change. . . a little. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
MrTMichaud Posted June 3, 2019 Share Posted June 3, 2019 That is similar to how I hope to get mine to look like by end of summer. Winter will prove a bit tricky to work in it. For me anyway. Some days in January and February is doesn't get above 0 F. AT least I get more daylight on those days that Frosty does. Then again, at this time of year, Frosty gets all sorts of daylight. I'm jealous of that, and the fishing. Quote Link to comment Share on other sites More sharing options...
arkie Posted June 3, 2019 Share Posted June 3, 2019 Without going to the labor and expense of hard-siding your smithy for winter, you might consider some drop down tarps for the sides and something "relatively" safe for heat, like a Mr. Buddy heater. At least you might get it up to +10* inside...LOL. You nor'east guys are tough anyway. My setup is open sided under a metal carport. In winter, the cold is not too bad, but if the wind is blowing, no forging! Not that tough. LOL Very nice, compact smithty, BTW Quote Link to comment Share on other sites More sharing options...
Peppie Posted June 4, 2019 Author Share Posted June 4, 2019 TY guys, I have a tarp that covers the side were the bench and the leg vise or located. I pull it down when I work out there. I have some bypass door hardware to be mounted for two sides away from the forge. Just haven't got to hanging it yet. I will use the same metal siding for the door panels. That should block the weather and keep most the heat in during winter forging. Quote Link to comment Share on other sites More sharing options...
MrTMichaud Posted July 8, 2019 Share Posted July 8, 2019 Tarp probably won't be happening. That would make it about 8x7. I'd have more luck convincing my better half to let me build a bigger shed... Quote Link to comment Share on other sites More sharing options...
Chris C Posted July 8, 2019 Share Posted July 8, 2019 Well, I'd have to say that's a mighty nice setup. Looks as if you've everything you need right there, nice and handy. I'd give it a thumbs up emoji if we had one. Quote Link to comment Share on other sites More sharing options...
