Jeff-Orl Posted May 24, 2019 Share Posted May 24, 2019 What is the best to use as a finish for something that is warn? Like a pendent? Boiled linseed oil will not do it. Quote Link to comment Share on other sites More sharing options...
jeremy k Posted May 24, 2019 Share Posted May 24, 2019 Renaissance wax. Quote Link to comment Share on other sites More sharing options...
Glenn Posted May 24, 2019 Share Posted May 24, 2019 On 5/21/2019 at 12:48 PM, Daswulf said: To preserve the patina, clearcoat is about the best bet. It will still darken up a bit, but not as bad as with BLO. I've been using an exhaust satin clearcoat spraycan clear that seems to be the most durable with nice sprayability. It's pricier than other spraycan clears but from my experience it holds up way better. This was posted in another thread for a item to show the patina and yet protect the object. There are several types of wax that can be used. Check to see if it is food grade if you are worried. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 24, 2019 Share Posted May 24, 2019 I think they mean worn as in "to wear" like jewelry; rather than worn as worn out. My suggestion would be to make it from stainless and passivate with citric acid. Quote Link to comment Share on other sites More sharing options...
Cedar Crest Forge Posted May 24, 2019 Share Posted May 24, 2019 Minwax has worked for me , for pendants. With the surface cleaned up and optionally blued, wax looks nice and holds up nicely. I have some forged pendants that are 20+ years old now, and are still looking good. I have never, nor will I ever, spray paint a wearable forged item. When the paint starts to flake off, it will become a throw away item to many consumers. Quote Link to comment Share on other sites More sharing options...
Jeff-Orl Posted May 24, 2019 Author Share Posted May 24, 2019 ThomasPowers... Sorry yes, Wear. Thinking and typing at the same time...At work doing a utility design... Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 11, 2019 Share Posted June 11, 2019 I like Trewax applied to fresh coffee temp item. It melts super thin and penetrating and gets into every nook and cranny. Wipe off the excess while it's still good and warm. Carnuba cools hard enough to chip if it's thick. Lasts a long time and doesn't stain or rub off. Carnuba is the wax used on bowling alleys that requires a drum sander to strip off. I love the stuff. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 11, 2019 Share Posted June 11, 2019 On 5/24/2019 at 12:31 PM, jeremy k said: Renaissance wax. My choice also. A little pricey but worth it. Quote Link to comment Share on other sites More sharing options...
