KYBOY Posted July 4, 2008 Share Posted July 4, 2008 Ill be honest, Ive never used a commercial flux befor. Ive always used borax. Is there really that much of a difference in commercial flux's compared to borax? Thanks Quote Link to comment Share on other sites More sharing options...
S.Willis Posted July 4, 2008 Share Posted July 4, 2008 I use borax mainly because I usually weld carbon steel and like it better for that purpose. When I do just weld mild I use ez weld and really like the results it gives but there again I have used borax numerous times on mild. It is probably a matter of opinion and what your use to. Quote Link to comment Share on other sites More sharing options...
civilwarblacksmith Posted July 4, 2008 Share Posted July 4, 2008 I have always just used borax and never had any problems, plus it is readily available from the grocery store when I need it. Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted July 4, 2008 Share Posted July 4, 2008 Try a couple for yourself and see. I would suggest EZ weld and Swans flux both are readily availeable at horseshoeing suppliers. Everyone that has tried Swans including myself say it is the best. But you will only find out if you try several. (Swans is also pricey) Quote Link to comment Share on other sites More sharing options...
