Whiskeymike Posted May 16, 2019 Posted May 16, 2019 Working on designing my forge skin. I'm planning a 4x7x12 internal work area. Inside will be lined with 2 inches of Kaowool, Rigidizer, 1/4" Kasto-like 30, and Plistix. Design is a small version of Essential Craftsman's forge where the top body separates from a floor which I think will make maintenance/modifications easier as well as the cool ability to temporarily in a pinch, raise it up with blocks to be able to heat something odd shape. Anything I've overlooked? Is there anything I should be doing to hold down the kaowool? Might be something I could design into the form. I'll be CNC plasma cutting the skin, then forming it on a box brake. Thanks, Mike Quote
Mikey98118 Posted May 16, 2019 Posted May 16, 2019 The biggest failing of ceramic fiber blanket is de-lamination; and that is only before it "takes a set" after two or three heat cycles. If you use rigidizer and heat the treated blanket up with your forge burner, then no de-lamination after that. All you need to hold rigidized blanket in place is a few screws inserted near the bottom of the forge sides. The weight of the refractory layer can be held in place by end tabs at front and back of the forge shell. Quote
Peppie Posted May 16, 2019 Posted May 16, 2019 This is how I held the wool and refactory in place on my shell Quote
