Patrick the Smith Posted May 16, 2019 Share Posted May 16, 2019 Hello building a forge It's starts with an old 7gal. propane tank I have good refractory bricks to line forge . Portion where flame/torch will be is completely in circled with brick. What could be used to go between brick and outer metal shell to keep shell from heating or is it even possible ? hope someone can help thanks all Quote Link to comment Share on other sites More sharing options...
pnut Posted May 16, 2019 Share Posted May 16, 2019 Welcome to IFI, check out forges 101 thread. Bricks take a long time and use up a lot of fuel to heat up if they're hard firebrick and If they're soft firebrick they won't stand up to the rapid heating and cooling in a forge for very long. Kaowool and castable refractory are the way to go. Someone with a lot more experience will be by to help you before long. Good luck and welcome to the addiction. Pnut (Mike) Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 16, 2019 Share Posted May 16, 2019 Welcome Patrick... Have you read this yet? READ THIS FIRST it will help you get the best out of the forum. Where in the world of 150 or so countries that participate here are you located, hence the suggestion to edit your profile to show location, because so many answers depend upon knowing where you are located. Quote Link to comment Share on other sites More sharing options...
Patrick the Smith Posted May 18, 2019 Author Share Posted May 18, 2019 I thank all of you for your advice and comments, I have updated profile as suggested , I'm sure I'll figure out how to post correctly. Looking forward to enjoying all the info this site has to offer. And once again thank you all for the help. Quote Link to comment Share on other sites More sharing options...
