racer3j Posted July 4, 2008 Share Posted July 4, 2008 My new Vulcan was described as 3/4" hardy. Not really- most of my hardy tools that shank size wont fit. The face is good hard steel and a file just skates in the hole. Any suggestions for enlarging? I have a die grinder and carbide bits for steel/iron but that could get ugly. Suggestions?mike Quote Link to comment Share on other sites More sharing options...
hammerkid Posted July 4, 2008 Share Posted July 4, 2008 make new hardie tools that will fit it (keep checking if it fits ) or you could make the shanks fit in it and weld em on you hardie tools Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted July 4, 2008 Share Posted July 4, 2008 Hey Racer. I bought an old anvil that measured 3/4 inch at the face. But down in the hole was less. My hardy tools wouldn't fit. So i made new hardy pins from RR spikes(They are about 3/4inch), and heated them up to a bright orange. Drive it in the hole and wiggle just a bit. Then use a punch or the like and tap them out from the bottom. When you get them to fit, after they cool, cut to length and do as hammerkid said. Weld them on the bottom of your tools. Quote Link to comment Share on other sites More sharing options...
S.Willis Posted July 4, 2008 Share Posted July 4, 2008 Like the others said best to make those shanks fit if you plan on keeping the anvil. The ones that you can get to hammer you couldheat and beat them down a bit Quote Link to comment Share on other sites More sharing options...
racer3j Posted July 4, 2008 Author Share Posted July 4, 2008 Great sensible advice. I was thinking my big 7" angle grinder and change the hardys. I like the RR spike idea as well. I think these hardy tools are malleable or ductile iron- I'll have to ask Beckley. Thanks for screwing my head back on straight. I would have been changing my truck to fit the gas cap.mike Quote Link to comment Share on other sites More sharing options...
matt87 Posted July 4, 2008 Share Posted July 4, 2008 Cast iron huh? What tools are they? Quote Link to comment Share on other sites More sharing options...
Jose Gomez Posted July 4, 2008 Share Posted July 4, 2008 I use a tool like this Harbor Freight to re shape the hardy hole on almost every anvil that I rebuild. I have found that it is easier to re-shape the hole to a common size than fight to make every tool that you want fit the anvils odd hole size. Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted July 4, 2008 Share Posted July 4, 2008 Jose, That is a great idea!! I didn't know that there was a 1/2inch sander. I've got it on my WISH LIST. Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted July 4, 2008 Share Posted July 4, 2008 They now have both electric and air powered ones Quote Link to comment Share on other sites More sharing options...
racer3j Posted July 4, 2008 Author Share Posted July 4, 2008 I ran out to HF and got one. It would barely cut the steel. So, out with the die-grinder and carbide burrs. My hardy tools slip in nicely now. Then I used the 1/2" belt sander to ease everything. I really wanted the anvil to be "right." I have heard that a few anvils have lost their behinds from forcing a hardy tool.mt Quote Link to comment Share on other sites More sharing options...
civilwarblacksmith Posted July 4, 2008 Share Posted July 4, 2008 I didn't even see that machine at HF when I lived there for a day. That is is a neat tool. Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted July 9, 2008 Share Posted July 9, 2008 I have a Hay Budden 116 lb anvil in the trailer. I found a Champion hardy but the stem was small fitting in the hardy hole in the anvil. I just welded some 1/8 x 1 to the stem of the hardy and cleaned up a smidge with a flap wheel. Now the hardy fits the anvil like a saddle on a sow. Many ways to fix things. Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted July 9, 2008 Share Posted July 9, 2008 Like a saddle on a WHO?!! Ten, yer somethin' else!!! LOL Quote Link to comment Share on other sites More sharing options...
hammerkid Posted July 9, 2008 Share Posted July 9, 2008 Hey Racer. I bought an old anvil that measured 3/4 inch at the face. But down in the hole was less. My hardy tools wouldn't fit. So i made new hardy pins from RR spikes(They are about 3/4inch), and heated them up to a bright orange. Drive it in the hole and wiggle just a bit. Then use a punch or the like and tap them out from the bottom. When you get them to fit, after they cool, cut to length and do as hammerkid said. Weld them on the bottom of your tools. Good advice !!!! Itry that on my hf 55 that i use for demos;) Quote Link to comment Share on other sites More sharing options...
