Forgingforfun Posted May 13, 2019 Share Posted May 13, 2019 Fired up forge Saturday was running a little funny but got a little done.tried a bottle opener but when i went to punch tab for cap ,it was too cold and split 20190511_134529.mp4 Quote Link to comment Share on other sites More sharing options...
Cedar Crest Forge Posted May 13, 2019 Share Posted May 13, 2019 4 hours ago, bill duckworth said: ,it was too cold and split Must have been really cold if it was mild steel. Or maybe you meant it was too cold outside, so you left the forge area. Just kidding, Did you try to include a video? The video is blank for me. Try a picture or two instead? And I am not sure if you are asking a question, (how to fix the situation) or just making a general comment. :) Quote Link to comment Share on other sites More sharing options...
Forgingforfun Posted May 15, 2019 Author Share Posted May 15, 2019 Just commenting was using 1/8 inch thick mild steel was punching tab at black heat and then got split, have a good drift and pritchel plate on order, and gonna use some thicker stock next time around Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted May 15, 2019 Share Posted May 15, 2019 Punching at black heat will cause splitting every time. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 15, 2019 Share Posted May 15, 2019 I recently cracked one just starting the drift a bit cold. Mine was in hotdog steel. Good reminder to keep the work in the upper temps for this. You want a full heat to start punching, then duller red to punch the slug through from the other side. Black heat is no go. Drift at full heat. Quote Link to comment Share on other sites More sharing options...
Forgingforfun Posted May 16, 2019 Author Share Posted May 16, 2019 Awesome thanks my burner was acting funny a little wonder bottle low and icing up best I could get was orange heat, plus thin stock losing heat was about 60 degrees out also Quote Link to comment Share on other sites More sharing options...
BillyBones Posted May 19, 2019 Share Posted May 19, 2019 Bill, are you floating that tank in water? Helps keep the ice down. This past winter i froze my ice bath one day so i invested in another tank. For a while i would bounce from one to the other as they would frost. About 2 months ago my boss gave me a 3rd tank. Rather than try and bounce between 3 tanks i looked into this a little more. From what i gathered it is all about surface area. I invested in some fittings and plumbing and ran all 3 in series. When they get very low, i mean like 1" in the bottom they will get a little bit of frost but not much at all. I do not have to run near as much pressure and my gas is lasting much longer. I went from about an 8 hour run on 1 tank to close to 40 on all 3. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 19, 2019 Share Posted May 19, 2019 When I worked at the forge in winter I put a tank blanket and two magnetic engine block heaters on my 100 lb. tank the night before. A 100lb. tank won't freeze up. Propane freezes at - 40f. but still sublimates enough to run your kitchen range provided it's at least 1/4 full. I only use a 20 lb. tank for short portable runs, even the NARB starts slushing a full one in about 2 hrs. at it's too small a volume to make sufficient pressure. A 40 lb. tank is good for about 6hrs. on both NARBs running welding temp. Audiences love a bright yellow forge even if it's not really necessary. But demos are theater so you do the entertaining stuff. If your tank's full and freezing, get a larger one. Easy Peasy. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Forgingforfun Posted May 19, 2019 Author Share Posted May 19, 2019 Thanks for the tips, I'm just a hobbyist with many years of attending meets and 2 abanas. Made my first chisel when I was 13 and then a knife, made some knifes over last 20 years, only now trying to blacksmith vs forge knifes. So much easier to play with mild steel vs high carbon have a homemade charcoal forge but gonna change from furnace blower to hand crank and to coal finding time is my biggest problem Quote Link to comment Share on other sites More sharing options...
BillyBones Posted May 20, 2019 Share Posted May 20, 2019 Frosty, i actually got the idea of running in series from my drag racing days. We would run 2 NO2 bottles in series to keep pressure from dropping when you hit the juice. A pressure drop will cause a piston to blow. Anywho, one of the other ideas i was floating was the heated blanket. We would wrap the bottles with a bottle heater, a heated blanket. That was also to keep the pressure up. I actually almost posted here asking if you could do that. I was going to get a 40#er but my dad gave me 1 tank, my boss the other, and only 1 i purchased at $30. The hoses and fittings cost all of $20. So $50 bones or shell out another $90 for a 40# and have 3 20# just lying about for who knows how long. Oh, i consider it a sin to use a propane grill so no cooking with them. I am by no means saying my way is best, just what works for me. If my ideas help i am happy to have helped. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 21, 2019 Share Posted May 21, 2019 Billy: While most of us have our own way of doing things and we positively delight in disagreeing in print I THINK I can speak for all of us in saying you shouldn't plumb your propane forge with NO2. I want VIDEO though! No need to buy new, keep an eye open at yard, garage, etc. sales, read the cert date and remember most folk have more trouble getting rid of old propane cylinders than fining them. Any grill in a storm. We're all sinners after all. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Cannon Cocker Posted May 21, 2019 Share Posted May 21, 2019 Check with your local propane dealer and get a used 100# tank. Then take that to a welding supply store that does exchange programs with the bottles. I get 100# of propane for just over 60 bucks. That's about 1/3 of the price I was paying with the grill sized bottles... Quote Link to comment Share on other sites More sharing options...
BillyBones Posted May 21, 2019 Share Posted May 21, 2019 Oh, lord no. I was meaning i got the idea of running the plumbing from my NO2 set-up. Not using NO2. Nothing put propane and propane plumbing. 100# for $60, i am guessing i am paying about the same per pound. Is that the price for delivery? Cause my old bones cant see hoisting 100# of propane in and out of the truck every couple weeks. Oh, another thought i just had, i live in suburbia i may not even be allowed a tank that size. Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted May 22, 2019 Share Posted May 22, 2019 Good Morning, Propane Tank freezing means you are drawing more than the surface of the Liquid can deliver. Simple, join 2 or 3 bottles together, just need a couple Tee's and a couple hose adapters, still use one regulator. By doing this, you increase the surface area of the liquid Propane, you cut your draw from each bottle in half or in thirds. Did you ever wonder why Drywallers have up to 6-100lbs tanks hooked in together, trying to dry the drywall mud. Same theory!! Look at a Residence or a Business that uses Propane, the big tanks are on their side. Lots of surface area = lots of draw. Neil Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 22, 2019 Share Posted May 22, 2019 8 hours ago, BillyBones said: Oh, lord no. I was meaning i got the idea of running the plumbing from my NO2 set-up. Not using NO2. Nothing put propane and propane plumbing. Darn, I wanted to see the video. It WOULD BE HOT. And too dangerous to actually try! Anybody reading my last couple posts I AM JOKING about hooking your forge up with nitrous injection, it'd be WICKED DANGEROUS! Right now Propane is in the $2.50?/ gl. range here and a 100 gl. tank holds around 25 gls. That's a rule of thumb number I'm not looking it up. A 40lb. tank holds roughly 8 gl. If you think you'll go through 100 lbs. in a couple weeks you might consider having a residential tank, say 100 gls. installed. Rental (demurage) isn't bad and they deliver. 100 lb. tanks don't freeze up even in sub zero weather. It has to drop below -40 f. before propane starts getting slushy and in a large tank enough will sublimate from the surface to run appliances. I don't know about forges though, they draw considerable volume. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
BillyBones Posted May 25, 2019 Share Posted May 25, 2019 The last time i had them filled 3 20# took about 12 1/2 gal. The bill came out to just about $33. So around $3 a gal, a little less. A couple places around here charge a flat rate to fill the tanks. $17 for a 20# no matter if it is empty or half full. Needless to say i do not go there. TSC i have found is about the cheapest in this area. I live in suburbia and i would bet a dollar to a doughnut that i am not allowed to have a residential tank on my property. Heck i am supposed to keep the grill 50' from the house. That is a long walk to flip a burger. Quote Link to comment Share on other sites More sharing options...
Glenn II Posted September 24, 2019 Share Posted September 24, 2019 On 5/25/2019 at 8:33 AM, BillyBones said: That is a long walk to flip a burger. Or a long walk back to get another beverage...if tending a long-term BBQ delicacy. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 24, 2019 Share Posted September 24, 2019 Check the local ordaninces; you might be surprised about the residental tank deal. Perhaps a local Propane supplier would know. Quote Link to comment Share on other sites More sharing options...
CrazyGoatLady Posted September 24, 2019 Share Posted September 24, 2019 I get propane at TSC. It is 2.36 a gallon right now. Quote Link to comment Share on other sites More sharing options...
BillyBones Posted September 24, 2019 Share Posted September 24, 2019 TSC is where i usually go. They are the only ones around who sell by the Gal. and not just $18 a tank no matter how much is left. 4 hours ago, Glenn II said: Or a long walk back to get another beverage...if tending a long-term BBQ delicacy. I do like the ribs and a brisket on occasion, i would have to take a cooler with me. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 24, 2019 Share Posted September 24, 2019 Any place in our small rural town sells by the gallon save for the bottle exchange places---and they give a short filled bottle too. Quote Link to comment Share on other sites More sharing options...
Gongo Posted October 4, 2019 Share Posted October 4, 2019 I deliver propane for a living, it's very common to see 123 gallon tanks in the city. However to have propane delivered (here in Ontario anyways) you must have any propane powered equipment inspected for safety. Quote Link to comment Share on other sites More sharing options...
