angiolino Posted May 10, 2019 Share Posted May 10, 2019 metal fence tips should I build a metal fence like a construction site with corrugated sheets, I should make the poles and crossbars to screw them in, which material should I use? eleven meters long, 2 meters high, which materials I use which sections and how far away I put them, how deep I place the poles? the poles in t-section or in tubular hollow? thank you Quote Link to comment Share on other sites More sharing options...
Les L Posted May 10, 2019 Share Posted May 10, 2019 Angiolino, what type of wind speed do you have in the area the fence will be built? The maximum wind speed will make a difference on recommendations Les Quote Link to comment Share on other sites More sharing options...
George N. M. Posted May 11, 2019 Share Posted May 11, 2019 Also, it depends on why you are building the fence. What are you trying to keep in or out? If it is aesthetic, to keep an ugly view in or out, all you need is something opaque and will be structurally sound. If it is for security, to keep people or animals in or out, you have other considerations. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
angiolino Posted May 11, 2019 Author Share Posted May 11, 2019 even 100 km per hour, it is at the limit with the railroad, the railroad company does not take care of the maintenance of the area next to the tracks, bushes grow bushes reeds, the wind carries waste, wild animals and snakes nest. I would like to realize with metal tubes the frame on which to screw the corrugated sheets I plant fifty centimeters in the ground what do you recommend? http://www.cemensolai.com/cordoli2012/recinzioni-prodotti-266.html http://dogler78.org/let/ http://ixiqi.co/image Quote Link to comment Share on other sites More sharing options...
arftist Posted June 4, 2019 Share Posted June 4, 2019 Prefer 125 CM, set in concrete. Solid panels have much wind resistance (sail area). Quote Link to comment Share on other sites More sharing options...
angiolino Posted June 10, 2019 Author Share Posted June 10, 2019 honestly I only reclaimed the area where the fence was set up, I cut the bushes and weed the weeds, I made a couple of holes for the foundation plinths, but the ground is hard and stony, I have a lot of difficulty, if any user friend if you have any additional suggestions or suggestions, I invite you to participate, I have to hire a pickup truck to buy the material I need thanks Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 10, 2019 Share Posted June 10, 2019 You want suggestions for digging in hard stony soil? Other than a pick, spud bar or chisel and sledge to break it up. Renting a jack hammer is another. I've had some luck with my hammer drill, it's intended to drill holes in masonry with carbide drill bits and it has a setting that hammers as well as rotating the bit. I had limited success using my hammer drill breaking up hard soil and embedded rocks. Not a lot of success but some, it was a good way to start a hole to drive a stake into. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
angiolino Posted June 11, 2019 Author Share Posted June 11, 2019 thank you for your precious suggestions Quote Link to comment Share on other sites More sharing options...
angiolino Posted June 13, 2019 Author Share Posted June 13, 2019 I had made that tubular probe that works like a big chisel Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 16, 2019 Share Posted June 16, 2019 The round one? Carota per Buca palleto(?) or am I looking at the wrong thing? There's no one way to dig fence posts. I have a post hole digger and I've never used one I thought worked worth spit. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted June 16, 2019 Share Posted June 16, 2019 1 hour ago, Frosty said: There's no one way to dig fence posts Around here it's called dynamite. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 16, 2019 Share Posted June 16, 2019 But I don't know how to spell dynamite in Italian. You? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted June 16, 2019 Share Posted June 16, 2019 No and if I tried to have google translate it, I may get a visit from the men in suits & dark glasses. Quote Link to comment Share on other sites More sharing options...
SLAG Posted June 16, 2019 Share Posted June 16, 2019 English dynamite. Italian dinamite Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 16, 2019 Share Posted June 16, 2019 Yeah, too true. You might anyway, you posted the word in English on a world wide forum after all. Oh wait, we're in the clear, Slag just translated so the heat's off us! YAY! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
