Posted
First time forge build and first time post. I'm using a brake rotor with a 5 inch diameter hole on the bottom..where would I find a flange big enough to be able to bolt to the rotor? Thanks.
Posted
Cut a circle from metal that fits into the hole, then cut a hole in the metal the size you want to use. Think of it as a large washer or donut.
