Farmweld Posted April 21, 2019 Share Posted April 21, 2019 I just had a commission from a customer to build a handrail for their backyard pool. They supplied a picture of what they liked that they had found online and I had to modify the design to suit their requirements. I started with 2700mm of 50x25 solid flat and drew the end out over 1750mm to about 50x5mm and then fish tailed the end to start the scroll. This picture is half way through when I had the basic shape and the short end made as well. I made up the base out of 10mm plate plasma cut to suit and formed and then welded the whole lot together. Finished product (minus the mounting frame) on the wall outside the workshop. The spike under the front is to stop it tipping over. Had the whole lot hot dipped and now I have to paint it. Here it is on a pallet after being hot dipped. I'll post some more pictures after it has been painted and installed Andrew Quote Link to comment Share on other sites More sharing options...
