zip Posted April 19, 2019 Share Posted April 19, 2019 I’m working on a project where I need a 2” section of a 1” diameter the bar to be 1-1/2” diameter. I don’t have any larger stock than the 1” diameter bar, and I tried upsetting a section and it was very slow going. An alternative I came up with is to use small 2” long piece of heavy wall tubing and forge weld that to the diameter of the 1” bar. I’d prefer it forge welded if it’s practical, it would be a good learning experience and the weld higher strength. Any specific approach in making the weld? Or is it simply flux the bar, slide the tubing section on, and forge the diameter in one direction working my way around to the starting point? Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted April 20, 2019 Share Posted April 20, 2019 Look up collaring Quote Link to comment Share on other sites More sharing options...
zip Posted April 20, 2019 Author Share Posted April 20, 2019 Found exactly what I’m trying to accomplish, round hot collar. Thanks for the suggestion! Quote Link to comment Share on other sites More sharing options...
