Bud in PA Posted April 3, 2019 Share Posted April 3, 2019 Any ideas on what I can use for a chimney for my forge, as 10 & 12 inch stove pipe is beyond my fixed income. Thanks Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 3, 2019 Share Posted April 3, 2019 Get the 6 inch and snap two together to make a 12 inch pipe stack or two 5 inch for a 10 incher. Link to comment Share on other sites More sharing options...
Stash Posted April 3, 2019 Share Posted April 3, 2019 Is there a difference between stove pipe and regular round duct pipe? I got 2 5' sections of 12" for under $30 new from the hvac supplier. I think stove pipe is double walled specifically for wood stoves and a lot more spendy. The duct pipe on my stack doesn't even get hot to the touch, and there is no creosote issue with coal. Steve (In PA, too) Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 3, 2019 Share Posted April 3, 2019 There is regular stove pipe, double wall stove pipe and triple walled stove pipe. There is also regular stove pipe in stainless steel---my woodstove has 1 section of stainless right above the stove where the temps are hottest. It's currently the most beautiful peacock temper colour. A lot of regular stove pipe has it where you can open it along the seam and add in another piece and so make it bigger in diameter. Helpful where folks have trouble accessing the larger sizes. For my forge I use a 10' section of spiral seamed HVAC duct work I got for US$4 when the ReStore was having a sale... Link to comment Share on other sites More sharing options...
Frosty Posted April 4, 2019 Share Posted April 4, 2019 You can use ducting for a forge stack IF you use something that isn't galvanized right above the fire. Plain steel stove pipe 12" long should be enough but 24" is better. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Please sign in to comment
