cap.vaageng Posted June 27, 2008 Share Posted June 27, 2008 Hi! I am a Norwegian presently living in Thailand with my family. I am a Merchant Marine Captain on tankers in world wide trade. I am experimenting with small Hydrogen fuel producing units (Primitive experimenting) & have a problem of getting workshops around to do what I need to have done. (Almost same as I want, is not good enough!):mad: So I decided to learn how to work with metals myself cutting / grinding is fairly easy. :rolleyes:The welding / soldering of parts is not! (Well, not to me!) As I have no ref. or experience in use of the various equipment. I have just started this Hobby at home to keep myself occupied while waiting for new employment. Today I purchased a small portable Ac/Ox set for 150$ since I figured it is more use full for other purposes as well as Cutting and welding. And I thought it might be easiest to start off with. (I can get MIG/TIG for around 200$ - up.) But I do not really understand the mix ratio of Ac/Ox, nor what sort of media to use as a welding rod as the shops tell my that I can Not use a normal Arc Welding rod for SS? I will mostly (To start of at least) be working with small pieces of SS SUS 304 that will have to be soldered / welded together. Anyone out there, who can give me a quick & easy briefing in the use of this Acetylene / Oxygen unit? Adjustment / preparations /general use? :confused: And also, I guess for MIG/TIG unit the price level should not matter to much since I am not a professional and the equipment will only be used when needed without having it running all days 24/7. Quote Link to comment Share on other sites More sharing options...
geofthesmith Posted June 27, 2008 Share Posted June 27, 2008 welcome to IFI! loads of informations here, so enjoy your stay! PS i cant answer any of those questions i just thought id welcome you Quote Link to comment Share on other sites More sharing options...
