Glenn
Inswool insulating blanket
1 inch thick, 24 inches wide. Price $8.50 per running foot (12 inches long x 24 inches wide x 1 inches thick). This material can be cut with shears.
Coverage depends on the size of your forge.
Shipping will be calculated on your entire order of materials.
SAFETY: Wear eye protection, a mask, and gloves when handling this product.  Ceramic Wool Insulation, Safety Alert
Contact me PM for your order.
Share this post
Link to post
You will need 2 layers of 1" 8lb. ceramic wool refractory (a high temperature insulating layer made from ceramic fibers) such as  Inswool insulating blanket. It is best to use two layers of 1 inch material rather than one 2” layer.
Measure the circumference of your forge subtracting 1/2 “ from the diameter (half the thickness of your wool) and cut ever so slightly large. This will create a fit that is tight enough to keep the wool rigid in place. Before adding the second layer, rigidized the first layer and burned off the water with the burner.  The color of the dye faded to white as the wool heated up. When it was basically gone stop the burner. It can take about five minutes, maybe a bit more. The second layer is added using the same math measuring from the new, smaller diameter created by the wool.
Share this post
Link to post
It isn't NECESSARY but it doesn't hurt. It will stiffen the insulating outer refractory a little more and so make a more stable surface to support the hard refractory inner liner / flame face.
This is discussed in depth in the Forges 101 thread.
Share this post
Link to post
 Inswool Ceramic Fiber Blanket  2300°F
Kast-O-Lite 30 Refractory 3000°F
Share this post
Link to post
Welcome aboard, glad to have you. You CAN make your own sodium silicate but there is a better rigidizer that has withstands higher temperature and is MUCH safer to make and use. Fumed / colloidal silica is commonly available at plastics and fiberglass suppliers, it's used as a thickener in resins where necessary. It's silly cheap even in Alaska. Mixed with clean fresh water, a little food coloring so you can see the coverage and sprayed on the Buttered refractory blanket with a spritzer works a treat. Once applied you cure it with a torch or the forge burner, red heat is plenty.
I bought a pint can, approx 3oz. of fumed silica for IIRC $8.00 and have used maybe 1/4 cup on two forges.
When I checked the HAZ MAT fees on the shipping for a few, 8 maybe oz of sodium silicate were prohibitive before you considered the price. Maybe EPA doesn't have everything in your state in the strangle hold it does here but sodium silicate was out of the question.
I don't know about buttering before using sodium silicate, I don't think sodium and water play nicely but being compounded with silica may change the chemistry. Check before applying it to anything wet.
Rigidizing with fumed silica does indeed work much better buttered first.
Share this post
Link to post
