DickyPitts Posted March 10, 2019 Share Posted March 10, 2019 I’ve been building my first larger blade (at least the first one I actually intend to complete) and I’ve just finished my first heat treat outside of punches and chisels in over a decade. This is 5160 from a new coil spring, forged in bevels and done entirely by hand. I don’t have a grinder that is up to the task, so I’m doing it the hard way. Any advise is appreciated. I was attempting to reach a blue spine with a straw to brown along the edge, I did better than I expected using a heated bar to cook the spine. I also attempted to submerge the edge and heat the spine with a torch... I need a new map-gas torch now. Thing was clogged up and didn’t work well at all. My question to you ladies and gentlemen, is this: Is a 5160 blade tempered mostly to a brown or straw brown, with quite a lot of blue near the tang, and the back varying between a brown and purple going to shatter the first time I try to use it for something? What should I be trying to reach color-wise for a medium length 5160 chopper? Thank you everyone. Link to comment Share on other sites More sharing options...
DickyPitts Posted March 10, 2019 Author Share Posted March 10, 2019 An update so I don’t sound like I didn’t do my research, I was attempting to replicate primitive methods to an extent. Files, forge, quench oil and time are my tools for this project. If it doesn’t come out well, no harm done. I’ve wasted nothing but my time and I’ll have learned something. Those of you using tempering ovens, or simply tempering in the oven, are you attempting a differential heat treat, or are you trying to get consistent properties throughout the piece? Seems like a larger piece would benefit from a softer spine and a harder edge. Link to comment Share on other sites More sharing options...
Frosty Posted March 10, 2019 Share Posted March 10, 2019 Good to see your web handle again! I'm no help with your heat treat question but I'm not about to let you post and not say hi! How are you and the family? My memory is too bad to recall your wife and little ones names. Where are our pictures?! Frosty The Lucky. Link to comment Share on other sites More sharing options...
DickyPitts Posted March 10, 2019 Author Share Posted March 10, 2019 Frosty! Great to hear from you man. We’re all doing great, have another baby girl about the same age now as my oldest was when you met her. I’m graduated and working as an engineer now and life is great! We move to a bigger house, still in the mountains and a lot closer to Denver. Leah, my wife is thrilled since it’s a 1940’s log cabin, and as an architect, it appeals to her aesthetic sense. My email hasn’t changed, it’s still the DickyPitts one. Shoot me whatever you’re using currently and I’ll send along some pics. How’s Deb? Link to comment Share on other sites More sharing options...
Frosty Posted March 11, 2019 Share Posted March 11, 2019 Pretty country, especially if you're a paleophile, I've loved dinosaurs since I was a little kid. Deb's doing really well, she's been teaching K 9 Nose Work for a few years now, her classes all have waiting lists. She bought a 1 year old 27' rental motor home with the proceeds. Maybe if the new wears off it she'll let me drive. I'm still just me, not as exciting as before the accident but doing well. Been getting things finished up in the shop a little at a time. Ran the bury power cable to it last summer and once my shop allowance builds up enough I'll get it hooked up. Almost no breakage in the earthquake: picture frames a couple coffee cups and only partially emptied shelves. We came through that in great shape, heck our well cleared in about 2 weeks even. The whole area including Anchorage and the bases came through with minimal damage for the magnitude of the quake. They're going to have to replace a couple schools here in the valley but they were darned old anyway. There weren't even major injuries, a broken leg in the quake. More people have been injured cleaning up and repairing things. Frosty The Lucky. Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 11, 2019 Share Posted March 11, 2019 What are you going to chop with it? Bone? Wood? Chicken? Elk?.... How does the edge react to a file? Have you looked into tempering tongs as a low tech method of replacing the torch? Immerse the edge and grab the spine with the hot tempering tongs. These were made from a set of pull offs with bars welded crossways on the end of the bits. Heat the bars HOT and can be done in multiple stages if needed. I would be most worried about getting an EVEN temper and not having it varying all over the place as a single brittle area will doom a blade that sees hard use. One trick is to set an oven to the lowest temper range you want and temper the entire piece at that before going back and drawing the spine to a higher temp "manually". Link to comment Share on other sites More sharing options...
Steve Sells Posted March 11, 2019 Share Posted March 11, 2019 close up of the head of tempering tongs I made Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 11, 2019 Share Posted March 11, 2019 hmm swivelling ends would give better contact; I'm going to have to think about this... I saw a set of standing seam metal roof tool that look a lot like tempering tongs for a 2 foot long blade at the fleamarket today... Link to comment Share on other sites More sharing options...
DickyPitts Posted March 11, 2019 Author Share Posted March 11, 2019 Steve, Thomas, Thank you for your response. It’s supposed to be a seax, so I would like to make it durable enough for camp use, shaving firewood, chopping brush, limbing small branches and trees etc. A file bites the edge just a bit, but doesn’t skitter off like it does on the bit of tang I didn’t wind up getting hot enough to temper. I’m going to have to anneal it and try again I think. Ah well, little more file work, now I know that tempering doesn’t scale up anywhere near as bad as getting the piece to forging heat. Thank you for the oven suggestion, I was wondering why people were posting about putting knives in the oven at 350 for hours, getting enough of a temper to prevent shattering prior to finishing sounds like good insurance. I had read about tempering tongs, just had forgotten. Thanks for the reminder, I might even have a pair lying around that have enough mass to get the job done already. Either way I have plenty of junk tongs laying around to play with. 1. Even temper via oven, I’ll probably do this for safety if nothing else, would there have been a primitive method (like hot tongs) to get a consistent temper, or would it have just been a matter of experience? 2. Hot tong the spine after getting the whole piece to a consistent straw yellow to brown, as was the expected temper color for medium carbon steel at 360 deg from on line. I’ve got an idea of where to go next, thanks! Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 11, 2019 Share Posted March 11, 2019 What temperature does your local vegetable oil boil at? Probably higher than you want; but a source of a consistent temperature. Remember that experience was a huge factor; the 7 year apprenticeship + years as a Journeyman before you could test for Mastership---if you had the capital! Steels were also much more variable and I expect there were considerable failures in practice. Medieval ovens were not a constant temperature. You fired them up, and then used them as they cooled slowly down. (I have friends that use wood fired masonry ovens to cook medieval and renaissance dishes in, been in the SCA 40 years now.) Link to comment Share on other sites More sharing options...
DickyPitts Posted March 11, 2019 Author Share Posted March 11, 2019 When you consider the challenges to practical metal work through history, it's pretty amazing that anything was produced at all, much less the impressive pieces that are extant today. I imagine a real seax would have likely not been a mono-metal construction since steel was so scarce/valuable. Most of the extant examples I've seen pictures of, appeared to be pattern welded; maybe from a wrought iron back with a steel edge, but I don't know for sure. I hear the silica in wrought iron makes it a lot stickier when you try to weld it. I've had minimal success with forge welds using mild steel. It's that experience thing again. Next time I'm going to try to file or grind my scarf to clean metal before I try to weld it, I must not be getting the surface clean enough with a wire brush. Olive oil boils at ~ 375 deg F at atmospheric, local pressure is around 11.3-11.4 psia at my altitude which would theoretically lower the boiling temperature. I can't find a latent heat of vaporization figure for olive oil so I'm not sure the exact amount it'll reduce the numerical value, but the idea does illustrate how a lighter oil could have been used to temper a piece. It also got me thinking about how the quench works from a physics standpoint. I guess the idea would be to try to remove heat at a fast enough rate to preserve some of the martensite crystalline structure, while allowing some interstitial carbon to migrate out and relieve stress and prevent shattering, the trick would be getting the heat transfer rate correct. When people bake their metal at ~360-375 deg F for an hour, does the time factor alter the tempering as opposed to bringing a portion of the piece to the point where carbon starts to migrate and then immediately quenching it? I wonder if more carbon migration or crystal phase change occurs during an hours's heat cycle vs the minutes to seconds needed to do a heat & quench style tempering. Link to comment Share on other sites More sharing options...
Steve Sells Posted March 11, 2019 Share Posted March 11, 2019 7 minutes ago, DickyPitts said: It also got me thinking about how the quench works from a physics standpoint. I guess the idea would be to try to remove heat at a fast enough rate to preserve some of the martensite crystalline structure, while allowing some interstitial carbon to migrate out and relieve stress and prevent shattering, the trick would be getting the heat transfer rate correct. When people bake their metal at ~360-375 deg F for an hour, does the time factor alter the tempering as opposed to bringing a portion of the piece to the point where carbon starts to migrate and then immediately quenching it? I wonder if more carbon migration or crystal phase change occurs during an hours's heat cycle vs the minutes to seconds needed to do a heat & quench style tempering. i have no idea where you are getting your mis information, there is NO martensite to preserve before or during the quench. It forms from austenite because of the quench if its fast enough., also there isnt a measurable amount of carbon migration during tempering either. Link to comment Share on other sites More sharing options...
DickyPitts Posted March 11, 2019 Author Share Posted March 11, 2019 Guess I need to do some more reading. I thought martensite was the formation at critical temperature, and you were “freezing” it in place during the initial quench. I was wrong though. Not my direct area of expertise for sure. Link to comment Share on other sites More sharing options...
JHCC Posted March 11, 2019 Share Posted March 11, 2019 Read this: Link to comment Share on other sites More sharing options...
Steve Sells Posted March 11, 2019 Share Posted March 11, 2019 16 minutes ago, DickyPitts said: I thought martensite was the formation at critical temperature Austenite is formed at critical temp Link to comment Share on other sites More sharing options...
JHCC Posted March 11, 2019 Share Posted March 11, 2019 And martensite forms from the rapid cooling (quenching) of austenite. Link to comment Share on other sites More sharing options...
DickyPitts Posted March 11, 2019 Author Share Posted March 11, 2019 JHCC, I read it, I even read it two days ago, prior to posting this thread. Just an example of pre-existing idea bias I guess. I can admit when I’m wrong. Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 11, 2019 Share Posted March 11, 2019 Body Centered Cubic becoming Face Centered Cubic as the temp goes up. (I gesture from my belly to my face when I'm discussing this with students.) Link to comment Share on other sites More sharing options...
Frosty Posted March 11, 2019 Share Posted March 11, 2019 Guys: Richard was my first "student" after moving to the woods. He's home schooled and driven to excellence. I don't know of many people who learn from mistakes, his or others, faster. He's already made some amazing accomplishments. Broke a leach field with a snowmachine once. (that's snowmobile for you in the lower 48) Just give it to him straight he can take it. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Please sign in to comment
