angiolino Posted February 25, 2019 Share Posted February 25, 2019 hello, I would like to make a small table with wheels to use to transport where I need a small portable 60cm long, 25 cm high 40 cm weight 7 kg weight 180 amps, some ideas, I've seen some for plasma cutting, some ideas , some photos, some design with measures thanks http://pdf.directindustry.it/pdf/cemont/catalogo-generale-2017/181804-727825.html https://weldingsuperstore.co.uk/brand-cemont.html Link to comment Share on other sites More sharing options...
setlab Posted February 26, 2019 Share Posted February 26, 2019 Those all look like good designs to make your own. Not much to building a table besides how tall you want it, mine are all about 36" tall in freedom inches. Other than I like my welding tables to have holes or slats to clamp stuff down in the middle of the table. Link to comment Share on other sites More sharing options...
angiolino Posted February 26, 2019 Author Share Posted February 26, 2019 thank you for the right suggestions if any friend user had photo drawings or other suggestions or useful tips, I invite you to speak and write thanks greetings to all of you, thanks for the active collaboration Link to comment Share on other sites More sharing options...
GMoore Posted March 30, 2019 Share Posted March 30, 2019 I built a 4' by 8' welding table with 6 metal wheeled casters. And, the things I learned from that, is that metal wheels on a welding table cannot be beat. Link to comment Share on other sites More sharing options...
Please sign in to comment
