Mtbarn Posted January 27, 2019 Share Posted January 27, 2019 I have access to dimension lumber scraps through work. Does anyone have experience with charcoal made from softwoods? Quote Link to comment Share on other sites More sharing options...
Laynne Posted January 27, 2019 Share Posted January 27, 2019 I started with hardwood charcoal but have switched to mostly soft wood from pallets. I get fewer fire flies, less ash, and I don't notice any difference in burn rate. If you aren't already making charcoal check out the threads on different methods. Lots of good information here. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted January 27, 2019 Share Posted January 27, 2019 Just make sure the scraps are not treated lumber. Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 27, 2019 Share Posted January 27, 2019 Softwood like framing lumber charcoal burns faster but hotter. Pallets are typically hardwood though not usually high quality. Hardwood charcoal lasts longer. BTUs per lb. are the same though. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted January 28, 2019 Share Posted January 28, 2019 Hard wood lump charcoal is not typically fully pyrolised, thus fire flees. To much air will exasperate the situation. Softer woods such as pine, Cotton wood, willow etc contain less silica thus produce less ash. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 28, 2019 Share Posted January 28, 2019 The 40# sacks of mesquite charcoal are particularly bad about not being fully charred as they WANT the mesquite smoke flavour to come through rather than the hot clean burn for forge work. As for softwood charcoal; As I recall it's used in Japanese sword smithing. And a lot of pallets are all softwood these days---look for the HT stamp it means they were heat treated rather than chemically dosed to prevent insects/diseases being transmitted by them. Quote Link to comment Share on other sites More sharing options...
Mtbarn Posted January 30, 2019 Author Share Posted January 30, 2019 Thanks everyone for taking the time to respond and for all the good information! Quote Link to comment Share on other sites More sharing options...
Sly Posted January 30, 2019 Share Posted January 30, 2019 Mn iv used hardwood, I typically might start with royal oak and then move to a cowboy charcoal once I have the heat. it sort of depends on brand My forge is just a narrow channel made of two brick walls only 5 inches wide though and about 14 inches deep so it gets much hotter then a grill type pile, I like to put a large chunk of dry firewood ontop to pack in the charcoal and insulate the stack. Hardwood is ashy, which is good and bad youl find yourself cleaning your steel/anvil more but its good for welding, bad for forging. Quote Link to comment Share on other sites More sharing options...
Mtbarn Posted February 21, 2019 Author Share Posted February 21, 2019 As a follow up to my original question, when do I size my charcoal? Should I break up larger pieces after they’ve been pyrolized or should I cut them to size beforehand? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 21, 2019 Share Posted February 21, 2019 Yes Definitely! (It converts to charcoal easier in a smaller form, but you seem to lose more to inter chunk friction when handling it that way,) As size of charcoal can be modified according to how YOUR forge works and what YOU are forging; I would experiment and see what works best for YOU! Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted February 21, 2019 Share Posted February 21, 2019 I never bothered to make charcoal first when I ran low on coal. I just tossed the chunks in and got a fire going. Worked it like a coal fire and added it around the edges, I just kept pushing it in as it was consumed. With enough air the smoke isn't that bad. Quote Link to comment Share on other sites More sharing options...
Mtbarn Posted February 22, 2019 Author Share Posted February 22, 2019 Thank you again everyone for the feedback. I’ll post some pictures if/when I build a charcoal retort. Quote Link to comment Share on other sites More sharing options...
