Laminate hunter with reindeer handle
BartW
Hello all,
New knife as a laminating experiment. Center layer (W2 steel) isn't in the center after grinding, hence the difference in sides.
But, it's ground full flat to zero, with a hrc 61 center layer. It even has a 30 degrees secondary edge (see the pics). It's extremely sharp. 6 mm spine.
Specs : laminate W2 with 7 layers 15n2 \ c75. Bronze pin, bronze guard.
8 inch blade. It's larger than it seems.
I love the lines. Very comfy handle too.
Time for pics.
What do you think?
