Owen Hinsman Posted December 3, 2018 Share Posted December 3, 2018 How would I go about smithing a saw? I’ve looked on YouTube, but have only found a few videos. I want to make something for cutting ice. Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted December 4, 2018 Share Posted December 4, 2018 Good Morning, Look at the one man saws they used to use to cut the Ice Blocks, to fill the Ice House. Think early refrigeration!! The saws are similar to the one man cross-cut saws they used for falling trees, except they were used vertical for Ice Blocks. Don't try to invent the wheel. It has already been done, a long time ago. Neil Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 4, 2018 Share Posted December 4, 2018 I googled for pictures and once I got past the SAW movies, discovered there were all kinds. Next time I wouldn't use the terms "Ice block saw." This is one of the image hits I saw. Pick something and we'll brainstorm ideas with you. https://images.search.yahoo.com/search/images;_ylt=Awr9BNxG8gVcl6YAjYdXNyoA;_ylu=X3oDMTEyNzR0aHVuBGNvbG8DZ3ExBHBvcwMxBHZ0aWQDQjQ4NTNfMQRzZWMDc2M-?p=Ice+block+saw&fr=crmas Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
George N. M. Posted December 4, 2018 Share Posted December 4, 2018 i think that the real trick is figuring out how much offset you should set into the teeth. I'm sure that ice needs a different kerf width than wood or metal. You might visit some museums and see if you can make some measurements on preserved ice saws. There should be a reasonable number left in Maine. For all that I know there may be extant jigs for setting ice saw teeth. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
duckcreekforge Posted December 4, 2018 Share Posted December 4, 2018 I looked at Frosty’s image suggestions: 1 and 4 are hay stack knives. Several of the others are the typical tiller handled ice saws. I have one like these. The set in the teeth can be hammered in (preferred), or wrested (twisted)(less preferred method). Nicer saws are thicker at the tooth and thinner at the spine, less set is required. Quote Link to comment Share on other sites More sharing options...
JHCC Posted December 4, 2018 Share Posted December 4, 2018 I've always thought the kind that gets pulled behind a horse is really cool. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 4, 2018 Share Posted December 4, 2018 How to make: High Tech---have the teeth laser cut before forging and heat treating. Low tech---cut the teeth cold with a good hacksaw, then dress and forge and heat treat. Blacksmith---hot cut the teeth and dress and forge and heat treat. This is definitely an item you want a differential hardening for and would profit from having a long trench forge. Differential tempering is also suggested. Note I would use an alloy suitable for an ax rather than a knife if you can't get a good saw alloy in that length (I would look into what alloy they use for large bandsaw blades----the 6" to 1' wide ones. Unfortunately those blades are probably too thin and flexible for you use---but the alloy should work!) Quote Link to comment Share on other sites More sharing options...
John in Oly, WA Posted December 4, 2018 Share Posted December 4, 2018 Then there's an ice fishing saw, which looks completely different. Ad said it was made of "durable, abrasion resistant steel". Quote Link to comment Share on other sites More sharing options...
JHCC Posted December 4, 2018 Share Posted December 4, 2018 2 hours ago, ThomasPowers said: Unfortunately those blades are probably too thin and flexible for you use UNLESS! You could, like the Japanese, design your saw to cut on the pull stroke. Since the blade will be under tension, it won't need the stiffness to resist bending under compression, and could therefore be a lot thinner. Quote Link to comment Share on other sites More sharing options...
Dave Budd Posted December 4, 2018 Share Posted December 4, 2018 i've never made an ice saw, but I've made a number of woodworking saws. The easiest way to make a large saw is to start off with some commercially available, pre-heat treated sheet or strip steel of the right thickness I got some sheet that is 1mm thick and at something like 52rc (i think), I cut the shape out with an angle grinder, carefully grind off the heated zone and then file the teeth in. Quote Link to comment Share on other sites More sharing options...
Owen Hinsman Posted December 4, 2018 Author Share Posted December 4, 2018 19 hours ago, Frosty said: I googled for pictures I quite like that saw with the stepped teeth. It seems like it would be easier to forge than a saw with triangualr teeth. Quote Link to comment Share on other sites More sharing options...
