Glenn Posted November 29, 2018 Share Posted November 29, 2018 What are some of the most useful ideas blacksmithing or otherwise you have run across? Large, small, simple, complex, as long as they were useful. A little explanation would be helpful as well. Link to comment Share on other sites More sharing options...
Shabumi Posted November 29, 2018 Share Posted November 29, 2018 This one is a little basic, but it's stood the test of time. If you put the hot thing onto a hard thing and hit it with another hard thing, the hot thing changes shape. Link to comment Share on other sites More sharing options...
dickb Posted November 29, 2018 Share Posted November 29, 2018 Basic but important ! Hold the black end, hammer the red end. Link to comment Share on other sites More sharing options...
JHCC Posted November 29, 2018 Share Posted November 29, 2018 Hot metal behaves like clay. Just don't try to mold it with your thumb. Link to comment Share on other sites More sharing options...
Al Stephens Posted November 29, 2018 Share Posted November 29, 2018 Do your thinking before you pull it out of the fire. Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 29, 2018 Share Posted November 29, 2018 Actually there is a powerhammer tool called the thumb, (or for Sherlock Holmes fans, The Engineer's Thumb). You use it to smoosh hot metal around like you would clay with your thumb; but using the powerhammer and a handle to do it "remotely". Link to comment Share on other sites More sharing options...
Glenn Posted November 29, 2018 Author Share Posted November 29, 2018 When reusing plastic buckets the small plastic handle on the bail or handle is uncomfortable Cut a piece of hose the long way, place it on the handle, and wrap it with tape. The larger size is more comfortable and does not cut into the hand. Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted November 30, 2018 Share Posted November 30, 2018 Using good personal protection equipment will save you many ways, as in medical costs, pain & suffering, lost production, etc. So don't skimp on aprons, gloves, ear protection, eye protection, respirators. Remember they won't do you any good hanging on those fancy hooks you forged. Link to comment Share on other sites More sharing options...
rockstar.esq Posted July 8, 2019 Share Posted July 8, 2019 Sand in a bucket is a very easy tool for cleaning oil off a quenched part. The sand gets into all the little nooks and crannies. Sawdust works pretty well provided the part is cold. Be very careful when quenching tubular stock as the "cold" end can erupt with dangerous steam. Link to comment Share on other sites More sharing options...
Kozzy Posted July 8, 2019 Share Posted July 8, 2019 Paying more for better quality tools is generally less expensive in the long run than buying cheap. Sandpaper and drill bits are prime examples but it applies to most of what you buy. Sometimes it's better to do without (or make do with what you have) while you save up for the improved quality version. Cheap air tools are another prime example. They are sure appealing by price but the life and reliability are really iffy...and they generally can't be rebuilt properly when they do fail. Oh..and keep a separate set of junk tools for people who borrow or to take to job sites where tools sometimes may walk away. That's where the crappy stuff is actually of benefit. Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 9, 2019 Share Posted July 9, 2019 Buying top quality used, but not abused, is often better than buying low grade new---for one thing the better grades are usually designed to be repairable and parts are available for them. Link to comment Share on other sites More sharing options...
rockstar.esq Posted July 12, 2019 Share Posted July 12, 2019 A few years ago I discovered that there are three separate part numbers for every individual component in an appliance. The first is put on the part by the factory. The only internet search results that will return this number are repair blogs, and people selling salvaged or "new old stock". The second internet search result, is the "replacement part" number. The sites selling these will charge 30-40% less than the next option in my list, but they do not allow returns, nor do they provide appliance make and model information to confirm the replacement part's compatibility with a given appliance. I'm guessing that these internet retailers are catering to appliance repair technicians. The third, is the part number you'll find if you search the internet by the make and model of the appliance. The sites selling these will charge roughly 5% below whatever an appliance repair company will quote to furnish and install the component. They do however, provide verification that the part will actually fit a specific make and model of appliance. Everything about this seems to be geared towards the do-it-yourself customer. To the best of my knowledge, there is no publicly available cross-reference between the last two part numbers. It seems entirely possible that one part retailer might have separate "internet storefronts" for repair techs, and DIY people. For what it's worth, I noticed that both types of sites use the same stock photos of the part which virtually never show dimensions, or definitive component characteristics like an end-on view of connection points. So what does all that mean? A do it yourself person can very likely repair their appliance for half the cost of a repair company. However, the part number tags are typically mounted in the appliance so they cannot be read without major disassembly. That's half the work of replacing the part, and if you buy the wrong thing through the "replacement part number" retailers, you can't return it. However, if you wanted to roughly approximate the service guy's repair cost for a given part, you could search by the appliance make and model. Add 5% or so to get yourself in the ballpark, so long as you keep in mind that we're talking about component level (pumps, sensors, control boards, etc), not individual washers and screws here. I've found similar schemes with replacement parts for common power tools as well. Commutator brushes and drill chucks are a great example. If you search by the make and model of the power tool, the parts often cost more than if you search by the part's actual number. Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 13, 2019 Share Posted July 13, 2019 Repair costs also depend on where you are. We often have an 75 mile each way drive cost added to the quote. Link to comment Share on other sites More sharing options...
Please sign in to comment
