New DYI Welding Table
Peppie
My last welding table was a total failure. The top was pieced together with material I had on hand. After it was all weded together.. the top looked like a twisted rollercoaster.
 This one has a 5/8 , plate top ( 2' X4'). Legs are 2 X 4 tube, with 4" channel for rails. Heavy little sucker! Approx 300lbs
I made adjustable feet, and added a custom plate to the end to mount my Wilton.just needs a shelf, and a couple coats on paint on the stand.
32 minutes ago, Chelonian said:
Looks like a great table. How well supported is the vise? Beautiful Wilton Bullet BTW.
TY the vise has a piece of angle welded under the base, that extends back intop the underside of the top. Hopeing it will hold up in time. If not I will add an angle brace down to the frame for a more rigid mount. Was trying to keep the top removeable. The Wilton will get light use. The leg vise on the other side of the forge will handle all the heavy work.
