Gavj75 Posted October 22, 2018 Share Posted October 22, 2018 Hello people. I'm not to far off from attempting my first hand hammered Damascus and my question is this:- From the steels which I have, which ones will work best together to forge a nice light/dark contrasting stripey Damascus? I have access to ''heavy-duty steel bandsaw blade'',''steel banding''(used for banding steel down on pallets),various different ''leaf springs''(5160 I think) and some ''circular saw blades''. I would appreciate any advice from anyone that may be able to help me with this. Thank's, Gav Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 22, 2018 Share Posted October 22, 2018 Place a drop of your etching solution on a cleaned spot of each and see what it will look a lot like in use. Note if your circular saw blades contain chromium they will be difficult to weld. I've had a lot of luck with bandsaw blade and pallet strapping---for blades use the pallet strapping that will break easily in a quench and break test. I'm assuming this is for blades. Damascus doesn't have to be made into a blade...but the location seems to indicate it's for a blade. Link to comment Share on other sites More sharing options...
Jclonts82 Posted October 23, 2018 Share Posted October 23, 2018 I second TPs suggestions. I made a 1/4 decent dagger from BSB/PS. Tried it after reading his suggestions in MANY posts on the forums. The steels are usually cheap-free and that makes good practice. If buying new, 1080 and 15n20 have very similar properties (forging hardness, temperature range, hardening/tempering temperatures) Be sure to spend the time getting the layers as clean and straight/even as possible! Link to comment Share on other sites More sharing options...
Gavj75 Posted October 29, 2018 Author Share Posted October 29, 2018 Sorry it's taken me a little while to reply. Thanks for your advice guys as it'll help me out quite a bit. I wouldn't of thought about etching the different steels individually. I'll be over the moon if I can achieve something close to the results on your dagger. It looks really cool. Thanks again, Gav One last thing, is that a ladder pattern? Link to comment Share on other sites More sharing options...
Steve Sells Posted October 29, 2018 Share Posted October 29, 2018 twist Link to comment Share on other sites More sharing options...
Jclonts82 Posted October 29, 2018 Share Posted October 29, 2018 If I recall correctly, it was 11 full 360 degree twists. If/when you twist it, depending on how much you grind off, you get different patterns to show up. The left edge of the picture shows what some call a 'star' or 'starbursts' I believe the more you grind off, the more of that shows up. I would have loved to do so on this one, but my personal inexperience and lack of planning had me not use enough steel/forge a blade too long to have enough meat left on it to grind into to reveal the layers better. Link to comment Share on other sites More sharing options...
Please sign in to comment
