Simple folding Knife or Peasant Knife
BeaverNZ
BeaverNZ, it certainly doesn't upset me! I would call it an homage. Sometimes a production blade is just too cool not to tinker with. One of my favorite Bowie blades is the Cold Steel Trailmaster. Not a particularly high end knife, but in profile the lines are just..."right". You have the makings of something really special there and I look forward to seeing it completed. No one is going to mistake a blade as nice as yours for a Svord! Since you took the steel to a new level, maybe consider adding liners to the scales to further distinguish it as a Custom. Any rate, keep up the good work.
Its all done and I have used a coffee etch which did improve the contrast and using 2000 grit sand paper really helded as well, I had to make 6mm screws into 4mm screws which was a bit fiddley and the barrel was turned from a bronze bolt. I think I will make some more of this style of blade
