Table for my Forge (cont.)
So after getting everything to make the table for my forge from my very generous neighbor. I’ve pretty much got it all put together. I had to weld plates to the bottom of the frame to be able to mount the wheels to it. All in all, it’s going well. The only thing I have left to do is clean up the table top and I want to weld up a cut that’s in it and then I can mount it. I will be putting up a barrier around it, minus right in front of and behind the firepot. Here’s what the frame looks like with the wheels though.
Unfortunately I wasn’t thinking when I welded the plate to the frame. The fourth bolt hole is over one of the square tubes so I either have to drill and thread or cut out a piece of the pipe so I can tighten a bolt. I think I’ll leave it with 3. Unless one day I get bored and wanna thread it.
