Heat shield for ceiling above gas forge
Gyrovague
My (new) shop has 7.5' ceilings, and my forge stand is fairly high, which means the (drywall) ceiling above the forge will soak up a lot of heat.  What should I put above the forge to protect the ceiling from heat?  It's not so hot that you can't hold your hand up there, but I would worry about running the forge for hours.
Ideas I have:
1) Sheet metal with 1" spacers.  This is apparently a common trick to protect walls from woodstoves.
2) A water heater blanket, laid out flat and stapled up there.
3) Refractory?  If so, what kind?  (I've never built a forge or messed with any of it.)
Anything else?
