t2harh Posted August 23, 2018 Share Posted August 23, 2018 I travel for work. I need to make a push/pull dowel slide hammer. Collet hammers will not work. My background, millwright and machine work too long ago. This tool will have multiple threaded points. Have to be very durable, pulling up to 25mm/1" steel dowels, up to 60mm in length. I'm a machine tool builder. Access to lathes and Bridgeports are pretty regular, most have no cooling lubricants available, as most of us are I'm on a budget and with many restraints, including any type of hardening and heat treating being the biggest. ( imagine a hotel that allows a forge). My machining abilities are better than average as most of my work is restricted to less than .1mm. My loss is the grades of steel that is economical, easy to procure, easy on tooling to machine, yet durable. Plan for those who can visualize, is 1" slide bar with adaptable heads for different size dowels with out welding, adaptable slide sections for more length as necessary. The hammer made from 2" round cut down in the middle to provide a handle that will not allow for pinch points. Any help is greatly appreciated. When I complete one I will provide pics and specs after testing. Do not want one to get injured if this fails. Thank you all in advance for any information that is easy for an old man to learn from.... Link to comment Share on other sites More sharing options...
DuEulear Posted August 23, 2018 Share Posted August 23, 2018 Seemees like 4140 heattreat would be the most likely to fit the bill as it is pre hardened and tempered to 25-35 hrc if you need a greater level of hardness you will most likely need to do a heattreat of some kind if so try an air hardening alloy like A2 and take a camping trip or find a buddy with a hairdryer and a bbq. enjoy du Link to comment Share on other sites More sharing options...
Steve Sells Posted August 23, 2018 Share Posted August 23, 2018 First rule about metallurgy is understanding what Iron actually is,. I will relocate this for you.since you posted this in non ferrous Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 23, 2018 Share Posted August 23, 2018 Welcome to IFI... a lot of answers depend upon where in the world you are located, hence the suggestion to edit your profile to show it. Link to comment Share on other sites More sharing options...
Please sign in to comment
