Chuyn Posted August 14, 2018 Share Posted August 14, 2018 Trying to get my first anvil. Found this one about 2 hours away from where I live. Anvil is located in northern California and is asking $500. I don't think he/she knows anything about the anvil. Would it be worth my drive? any advice? Quote Link to comment Share on other sites More sharing options...
Daswulf Posted August 14, 2018 Share Posted August 14, 2018 Arm&hammer brand. Cant quite make out the middle number of the weight stamp Dont forget your ball bearing to test the rebound. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 14, 2018 Share Posted August 14, 2018 It would be worth the drive, especially if the seller is open to a little haggling. In my area just about everything is a 2 hour drive for us. Quote Link to comment Share on other sites More sharing options...
Chuyn Posted August 14, 2018 Author Share Posted August 14, 2018 Thanks for the advice. Question about the rebound test. I bought some ball bearing from Amazon and I was wondering if there's a way to tell if the ball bearing have been hardened. Thanks! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 14, 2018 Share Posted August 14, 2018 If the middle number is a 9 then a good brand nearly 200 pound anvil in California at US$2.50 a pound seems like a good reason for a drive for me! Don't forget to haggle! Of course it's a 3 hour drive to get to my big shop from down where I work... Quote Link to comment Share on other sites More sharing options...
Daswulf Posted August 14, 2018 Share Posted August 14, 2018 Was there any clues in the item description on amazon? Like what they are made for? Never really tested a ballbearing. I get them out of wheel bearings. Quote Link to comment Share on other sites More sharing options...
Chuyn Posted August 14, 2018 Author Share Posted August 14, 2018 7 hours ago, Daswulf said: No need to quote what we just read. Finest quality AISI 52100 chrome steel " finest quality chrome steel produced in accordance with the highest industry standards. These high precision G25 ball bearings are hot forged from bar stock. Modern furnaces with precisely controlled atmospheres and temperatures are used for heat treating to assure uniform hardness and proper microstructure for each Stainless steel ball. Throughout the manufacturing process, statistical process control assures tolerance accuracy, fine surface finish and consistent high quality. Chrome steel balls offer the precise geometry and fine surface finish that makes them especially useful for bicycles, casters, drawer slides, door locks and many other applications." thank you and sorry if the answer is obvious about the ball bearing. I'll try and go take a look at it. Thanks for the advice Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 14, 2018 Share Posted August 14, 2018 Edges look a bit messy, but otherwise decent. If the rebound test is good and you are comfortable with the price, go for it. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted August 14, 2018 Share Posted August 14, 2018 Sounds like the bearings are hardened. Good luck with the anvil. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 14, 2018 Share Posted August 14, 2018 Take along a wire brush and with the sellers permission lightly brush off the loose rust on the face prior to doing the ball bearing test. A small hammer tapped all over the face will tell if there are any areas of DE-lamination (ring test) that could be a problem. Quote Link to comment Share on other sites More sharing options...
MC Hammer Posted August 14, 2018 Share Posted August 14, 2018 I second Irondragon on the wire brush. Rust and grease and oil can cause a ball bearing test to be way off. It sounds like you have a hardened steel ball bearing. Don't forget your tape measure or ruler and drop it from the 10 inch mark to make the visual easier. Looks like a good opportunity. Let us know if you go and what the outcome is. Quote Link to comment Share on other sites More sharing options...
Chuyn Posted August 14, 2018 Author Share Posted August 14, 2018 I contacted the seller and she wanted a PayPal deposited to hold the anvil for me just so I can go see it. She said she has other people interested and said she would only hold it if I did a deposit. Unfortunately I told her I didn't feel comfortable and told her to tell me if I could go see it if she didn't go though with her other deal. I'm 0-2 this past two weeks in getting an anvil. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted August 14, 2018 Share Posted August 14, 2018 Sounds fishy. Guess showing up with cash in hand isnt good enough these days? Quote Link to comment Share on other sites More sharing options...
Ranchmanben Posted August 15, 2018 Share Posted August 15, 2018 I’m with Das. Who would have thought of running an anvil scam? The requested deposit coupled with the seller not knowing anything about the anvil sends up a red flag for me. I’ve dealt with people that know nothing about anvils but they’ll still tell you what they can about the one they’ve got. Ask them for the serial number off the front foot, what sort of depression is in the base and other questions that they would only be able to tell you if they’ve actually got it. The anvil looks like it could be worth owning and making a drive for if the deal is legit and you don’t put down a deposit. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted August 15, 2018 Share Posted August 15, 2018 Yup, sounds scammy from my experiences. You did the right thing in telling her you're interested if the "other interested" people dont come through. If you get a call I would deffinately haggle harder. Could just be a ploy to get her price or more too. Had a friend deal with " that" scenario. No thanks.... head to the junkyard or a fab shop and get a good priced chunk of steel. Quote Link to comment Share on other sites More sharing options...
Chuyn Posted August 15, 2018 Author Share Posted August 15, 2018 Thanks guys! According to the seller she already sold the anvil that she supposably had. I wouldn't be surprised if she was just trying to scam me. Ooh well, I don't mind continuing my search for a anvil. I'm gonna try the flea market this weekend and spread the word that I'm looking for one. Quote Link to comment Share on other sites More sharing options...
tanglediver Posted August 15, 2018 Share Posted August 15, 2018 That sounds like an experience I had. ~~~ "Sure, c'mon down and have a look in the morning!" Called ahead the next morning, "Sorry, I have a buyer on his way already." Not meant to be. Soon enough though, you'll find your own. Quote Link to comment Share on other sites More sharing options...
Ranchmanben Posted August 15, 2018 Share Posted August 15, 2018 Had that happen to me too. Turns out I was the other buyer. Didn’t buy the anvil. Quote Link to comment Share on other sites More sharing options...
MC Hammer Posted August 15, 2018 Share Posted August 15, 2018 Yup, agree with all the others. What happens when you show up and they aren't there? Your paypal deposit is gone for sure. Other opportunities will come along. Quote Link to comment Share on other sites More sharing options...
