Posted
Is it against the law in no to have a propane forge in nj I had a neighbor complain and I think they are just being a xxxxx Wondering if anyone here might know about legality stuff in nj.
Posted
Steve,
The best source for legal questions,  in New Jersey, is the N. J. state Attorney General.
Ignorance of the law is NO defense: so lay people (non-lawyers) have to get it from somewhere.
In many jurisdictions the A.G. is legally obliged to supply same.
I'm not sure about N.J. but the odds are,  that it applies there too.
SLAG.
Posted
And if you check with them they probably don't have a clue about forging and gas forges.
I doubt that there is a problem but who knows what some bureaucrat will think.  I know that there are many blacksmiths and bladesmiths in NH using gas forges.
Let me know if I can help you.  You can find xxxxxxxxxxxxxxxx
I xxxxxxxxxxxxxxx
Wayne Coe
Posted
Polypropeline is what?
I would appreciate a clarification.
I looked it up on Wikipedia, and did not find anything.
thanks,
SLAG.
Posted
Charles,
Where should I drop  the poly? Oklahoma is a long drive away.
I wondered how POLY- propylene. could be used as a combustible gas.
The "propeline" misspelling threw me off.
Propylene gas burns hades hot. If you want hotter acetylene is the ticket.
Charles and Arkie thanks. Your clarification helped a lot.
SLAG.
Posted
dory about the mental slip.
Propylene fuel gas is what replaced MAPP gas in Canada and America; it is about one-third hotter than propane, and costs about one third more, when purchased in commercial cylinders from your local welding supplies store.
What matters to you is that it and other fuel gases have way less legal restrictions than propane does.
Posted
7 hours ago, SLAG said:
Charles,
SLAG.
The latest "MAPP" gas we use in our hand torches is mainly propylene.
  Quoting Wiki....."In early 2008, true MAPP gas production ended in North America when production was discontinued at the only remaining plant in North America that still manufactured it. However, many current products labeled "MAPP" are, in fact, MAPP substitutes. These versions are composed almost entirely of propylene with minuscule impurities of propane (<0.5%).[1]
