Old gas pipe
Relyks13
1/2 C. chlorine bleach to a gallon of water and let it soak a while will strip the mercaptan oil oderant. More bleach isn't better, you can do with less if you let it soak longer though. 1/2 C and filled with water will deoderize a 40 lb. tank over night EASY and that's 8 gls.
I suggest that rather than using the pipe use a 20# Propane tank.  The pipe will make a much heavier forge.  The tank's ends wrap around and help protect the casting and ceramic blanket, not to mention just making an all around better looking forge.
Sending people Off site removed
Wayne Coe.
