Frosty Posted June 29, 2021 Share Posted June 29, 2021 You're welcome. you can buy small quantities of forge supplies from the Iforgeiron store under the button at the top of the page. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Glenn Posted June 29, 2021 Share Posted June 29, 2021 The IForgeIron store (tab at the top of the forum page) sells quantities of material in 5 pound increments. This keeps the cost low and If you need more, order several. Quote Link to comment Share on other sites More sharing options...
Gandalfgreen Posted June 29, 2021 Share Posted June 29, 2021 Thanks for all the input fellas and hope I'm not a bother. Have a question pertaining to the kastolite I wondered if I sticks to plastic because I have access to a 3d printer and was thinking about printing a form to insert into my forge and then apply kastolite allowing me to coat all sides of my not quite circle not quite oval forge.? Thoughts ideas waste of time let me know thanks Gandalf. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 30, 2021 Share Posted June 30, 2021 It would be prudent to apply some release agent like Vaseline or spray Pam to the forum. Making a form is not a waste of time, makes it so much easier to put in the refractory. Quote Link to comment Share on other sites More sharing options...
Gandalfgreen Posted June 30, 2021 Share Posted June 30, 2021 Ok thanks see what I come up with. If not printer have another idea with old plastic cutting boards. Quote Link to comment Share on other sites More sharing options...
JHCC Posted June 30, 2021 Share Posted June 30, 2021 If you make a solid core, you should probably build in some degree of taper (say 1/4" per foot, maybe a bit more) to help with the removal. Quote Link to comment Share on other sites More sharing options...
Gandalfgreen Posted July 1, 2021 Share Posted July 1, 2021 Have time waiting see if buddy can make and already started backup plan. Have time didnt get silica coat on like planned was not sure if could go few days before I fire dried it and have busy schedule today thursday and friday. So more sponging of info for now till next week. Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 1, 2021 Share Posted July 1, 2021 On 6/29/2021 at 4:10 PM, Irondragon ForgeClay Works said: Vaseline or spray Pam to the forum. I didn't think it was that kind of forum! I LOVE a good typo, thank you. I found pam wasn't very effective but out of date Crisco worked a treat. I've read guys here who used linoleum rolled in a cylinder with the linoleum side facing the Kastolite and held with tape. Greased and used as a form inside or out. Once the Kastolite was set they cut the tape and either closed the inside form by pulling the overlap farther shrinking the form. Stripping an outside form was just a matter of cutting the tape and pealing it off. In my experience Kastolite sticks to every darned thing it touches including a plastic milk just I used to mix it. I couldn't get it clean, break the large pieces off but it's far from clean. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Gandalfgreen Posted July 1, 2021 Share Posted July 1, 2021 Ok got it what ever the form grease xxx xxxx out if it or it will be part if my forge. Or no form and do half at a time. Quote Link to comment Share on other sites More sharing options...
