Tyler Cech Posted June 4, 2018 Share Posted June 4, 2018 I have a couple of really old rail road spikes that I dug up while metal detecting. Would they be an ok steel to clean off and forge? Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted June 4, 2018 Share Posted June 4, 2018 Arrrrrrrruuuuuuugh !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Daswulf Posted June 4, 2018 Share Posted June 4, 2018 33 minutes ago, Tyler Cech said: Would they be an ok steel to clean off and forge? Well being this is in the knife making section then NO! No and No... . There are things they could be forged into. And depending How old, do you know how to test for wrought iron vs. Mild steel?, they would forge at different temperatures. In general for knives...no. unless..... Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 4, 2018 Share Posted June 4, 2018 The HC RR spikes are at the upper end of Mild Steel in carbon content. Blades made from mild steel are often called shivs (improvised knives as are seen in prisons) rather than knives. A lot of people make KLO's from them; but there are so many easily and cheaply sourced alloys out there that are MUCH better than a spike. Also beware that getting spikes from a RR right away is a felony and the RR police have amazing powers especially in these Homeland Security days. Quote Link to comment Share on other sites More sharing options...
Cavpilot2k Posted June 20, 2018 Share Posted June 20, 2018 They will, however, make a decent throwing tomahawk, or if you forge weld a high carbon bit on the end a nice working hatchet, but that is a topic for another section... Quote Link to comment Share on other sites More sharing options...
