bubba682 Posted May 14, 2018 Share Posted May 14, 2018 Runs good how much does the hammer weigh. Quote Link to comment Share on other sites More sharing options...
Jason Fry Posted May 15, 2018 Author Share Posted May 15, 2018 40 pound head. Tuned it up some More today. Hits plenty hard. Quote Link to comment Share on other sites More sharing options...
Jason Fry Posted May 18, 2018 Author Share Posted May 18, 2018 Ran it hard for three days with no major malfunctions. The way I had the dies set up to be interchangeable isn't going to work. It also hit much harder with a bit less space between the dies, but I was out of adjustment range, so I added a block of steel under the bottom die plate. I'll eventually need to lengthen the push arm to make up the adjustment. The weld between the bottom die and die plate cracked a little, and the bolt between the hammer shaft and top dies showed some pretty good wear. Looks like for the short term I'll have to weld up the interchangeable die parts to something more permanent, or at least change how the dies interchange. No structural failures or damage. Quote Link to comment Share on other sites More sharing options...
Jason Fry Posted August 20, 2018 Author Share Posted August 20, 2018 Update. Installed a stiffer spring on the spring pack, and lengthened the push arm. In this video I was forging some 3/8” square down a little further on the tail end of a blacksmith knife. Hammer was hitting so hard I had to slip the clutch a little. Was too smashy https://youtu.be/q3ZXB4kiT8Y Here’s what I ended up with. Quote Link to comment Share on other sites More sharing options...
FlatLiner Posted August 21, 2018 Share Posted August 21, 2018 I like your build. Looks like it works well. Quote Link to comment Share on other sites More sharing options...
Jason Fry Posted April 20, 2020 Author Share Posted April 20, 2020 Here we are two years later. Hammer is still running fairly strong. I've put about 30 hours on it in the last two months with all the virus quarantine, plus 5 or 10 hours a month since I built it. No major malfunctions, although I did break and re-weld the pipe that holds the lower guide. I also had to modify the way the top die attaches to the tup, as what I had wasn't strong enough. Finally broke the welds enough times that the force split the angle iron brackets. I recently read through "Pounding out the Profits" for the first time, and have a few ideas on ways to improve my hammer performance. I think maybe this weekend I'll build a connector to adjust the attachment point between the pitman and the spring, to see if moving the pitman closer to the tower will improve the stroke force. Also have several better guide designs in my head, although I probably won't do anything with them. I've done a few Damascus billets that were 2x2x6, and have forged out 1" by 2" by 3" pieces of solid as well. I haven't used any other hammers to compare it to, but it does the job I built it for. Quote Link to comment Share on other sites More sharing options...
