SoCal Dave Posted March 17, 2018 Share Posted March 17, 2018 I have a three burner Mankel forge with a blower. It uses a lot of fuel and I don't need all three burners all the time. If I want to use just two burners, which ones should I use and which one should I turn off? Is there a problem with the heat going up the turned off burner? I have the openings blocked off so the fire comes out of one end like a tube. Do I turn off the one burner nearest the opening or the one farthest back in the tube? Link to comment Share on other sites More sharing options...
Frozenforge Posted March 17, 2018 Share Posted March 17, 2018 Put a temporary wall in blocking the unused 3rd burner. You do not want exhaust gases going up the unused burner. You could also block it off shoving some kaowool up the inside of the burner. Link to comment Share on other sites More sharing options...
Please sign in to comment
