Mrye Posted March 4, 2018 Share Posted March 4, 2018 Cleaning out the barn after the passing of my father and found this anvil. I know it is old and weighs approximately 140lbs. Any ideas about it...make, value, etc? Thank you. Marla Quote Link to comment Share on other sites More sharing options...
Daswulf Posted March 4, 2018 Share Posted March 4, 2018 It's a Fisher anvil. They are considered good anvils. They have a cast iron body and a hardened steel faceplate. Value is pretty location oriented and also what value someone finds in it either as a collector or user. Looks like a good user anvil. Don't grind on it. Just wire wheel to clean it up if you want to. You might find a date on it. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted March 5, 2018 Share Posted March 5, 2018 MY 260# Fisher is my main anvil due to how quiet it is. Due to the construction of cast iron body with tool steel on the face and top of the horn they do not ring like other anvils. NJAnvilman here on the forum runs the Fisher Norris museum. The weight will be cast onto the base. The smaller anvil will use an abbreviated number that you times by ten to get the weight. 15 =150#. Fisher was very prolific and made over 500,000 anvils. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted March 5, 2018 Share Posted March 5, 2018 Welcome...To get the best out of the site, I recommend reading this thread. Quote Link to comment Share on other sites More sharing options...
Mrye Posted March 5, 2018 Author Share Posted March 5, 2018 Thank you for the information. Quote Link to comment Share on other sites More sharing options...
