AbundantSkunk Posted February 23, 2018 Share Posted February 23, 2018 I have a 4.5 in wide 10.25 in long and 7 in tall forge and the opening is 2in wide by 4.5 in tall propane forge. When I am trying to forge the inside of the forge doesn't get red or start to glow and my metal can barely get a dark red where the torches are. I closed off the back. I have 2 max heat torches and I'm using max heat propane. And I have coated the inside of my forge with itc 100ht. Any tips on what to do to make my forge hotter? Quote Link to comment Share on other sites More sharing options...
Hans Richter Posted February 23, 2018 Share Posted February 23, 2018 Hy Abu, welcome. Do you have any pictures? .............and some location anyway. Cheers, Hans Quote Link to comment Share on other sites More sharing options...
AbundantSkunk Posted February 23, 2018 Author Share Posted February 23, 2018 2 minutes ago, Hans Richter said: Hy Abu, welcome. Do you have any pictures? .............and some location anyway. Cheers, Hans Wichita K.S Quote Link to comment Share on other sites More sharing options...
Latticino Posted February 23, 2018 Share Posted February 23, 2018 You are using hard fire brick, which is a poor insulator, and a pair of small hand torches to attempt to make a forge. Neither of these is close to adequate. You need real high temperature insulation, a burner, and adjustable regulator. Please read through some of the posts in this section of the forum for additional detail. Quote Link to comment Share on other sites More sharing options...
AbundantSkunk Posted February 23, 2018 Author Share Posted February 23, 2018 1 minute ago, Latticino said: You are using hard fire brick, which is a poor insulator, and a pair of small hand torches to attempt to make a forge. Neither of these is close to adequate. You need real high temperature insulation, a burner, and adjustable regulator. Please read through some of the posts in this section of the forum for additional detail. Ok will do Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 23, 2018 Share Posted February 23, 2018 2 hours ago, AbundantSkunk said: Ok will do Welcome to IFI... We won't remember your location once we leave this thread. You might want to read this thread to get the best out of the forum. https://www.iforgeiron.com/topic/53873-read-this-first/ Quote Link to comment Share on other sites More sharing options...
jcornell Posted February 24, 2018 Share Posted February 24, 2018 To amplify on Latticino's comment - hard fire brick is a heat sink. Your steel won't get hot until until the entire forge is hot. Quote Link to comment Share on other sites More sharing options...
