graveyard Posted February 21, 2018 Share Posted February 21, 2018 i have Never forged welded i am looking to forge weld a rap tomahawk from a rasp will a hardier freight weed torch blowing into fire bricks give the heat i need to forged weld a begging in forged welding thank,s for any help Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted February 21, 2018 Share Posted February 21, 2018 huh ? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 21, 2018 Share Posted February 21, 2018 NO! Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted February 21, 2018 Share Posted February 21, 2018 It's kind of hard to understand this, but if you're asking what I think you're asking the answer is a resounding NO! The only thing you'll accomplish with that setup is an exercise in frustration and a lot of fuel burned. Take some time to read through some of the topics here regarding forge welding. Use the search engine on your favorite web browser and include "iforgeiron" in your search terms. That will get you much better results than the site search function. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted February 21, 2018 Share Posted February 21, 2018 May be I was being too hard on the poster, Obviously English is not his first language wherever he is from, Perhaps if he posts his location we can assist better in his language. All I can see from his profile is that he was been a member since July 2010 so not exactly a new member Quote Link to comment Share on other sites More sharing options...
Jasent Posted February 21, 2018 Share Posted February 21, 2018 I recommend reading the forges 101 thread. Quote Link to comment Share on other sites More sharing options...
John in Oly, WA Posted February 21, 2018 Share Posted February 21, 2018 A rap tomahawk - is that the kind you bend around in a U shape to form the handle eye and forge weld the two ends together for the blade? The answer is still no, you need a bit more heat than a weed burner can produce, and a neutral to slightly reducing flame atmosphere, which you could probably get in a brick pile forge, but not with that kind of burner. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 21, 2018 Share Posted February 21, 2018 I think that is a "Wrap" tomahawk from a farrier's rasp" (and still NO!) Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted February 22, 2018 Share Posted February 22, 2018 so not a Run/DMC hawk ? Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted February 22, 2018 Share Posted February 22, 2018 What would that even look like? Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted February 22, 2018 Share Posted February 22, 2018 no clue, but I was not the one wanting a rap hawk, I dont even want a hip hop hawk Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 22, 2018 Share Posted February 22, 2018 Would that be like a cross between a hawk and a "Hunga Munga"? Seriously I suspect he's asking about a "wrapped" hawk. In any case, your forge will NOT work, it's only slightly better than a kitchen range burner. Go charcoal if you can't or don't want to buy or build a proper propane burner. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted February 22, 2018 Share Posted February 22, 2018 Doing a wrap around forge weld with a Harbor Freight weed burner will not be very effective unless you can get enough bricks to form an enclosed forge to help hold the heat. Also some of those weed burners do not put out a strong enough flame to do it. You would probably do better with a fire pit and charcoal. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 22, 2018 Share Posted February 22, 2018 weed burners tend to be very oxidizing as well. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 23, 2018 Share Posted February 23, 2018 They're intended to light weeds on fire NOT heat things. They're BARELY up to fire glazing raku pottery and that's well below forging temp let alone welding temp. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
jlblohm Posted April 5, 2018 Share Posted April 5, 2018 It is possible!!! Here is how i did it. Link removed I dont think the one with a spark igniter will work though. Quote Link to comment Share on other sites More sharing options...
