WelderToTheMex Posted February 16, 2018 Share Posted February 16, 2018 I was given the task of fabricating a trailing shield in order to weld titanium pipe, but i came across a road block. I am planning on using steel wool in the trailing shield to spread the argon as i weld. The problem is I can't use regular steel wool because is will contaminate the Titanium. I have looked for stainless steel wool in local stores but have had no luck. Is there any other material I can use that will be safe to use and won't cause contamination? Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 16, 2018 Share Posted February 16, 2018 Grainger sells stainless steel wool as does a number of other places. Did you search on the net for Stainless Steel Wool? For a local item would one of the stainless steel pot scrubbers work? As regular steel wool burns at a touch of a spark I would think it was unsuited to the purpose. I have not tried the experiment with stainless steel wool but as it resists oxidation better it might work. Of course NOT KNOWING WHERE YOU ARE AT makes it very hard to suggest sources. We have over 150 countries participating here so what's right down the road in Perth Australia may be prohibitively far away in Iceland! Link to comment Share on other sites More sharing options...
WelderToTheMex Posted February 16, 2018 Author Share Posted February 16, 2018 Thank you, the stainless steel pot scrubbers might actually work. I'm working in a shop in Houston TX. I did find stainless steel wool online but it would take a couple of days to come in and this project is time sensitive. Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 16, 2018 Share Posted February 16, 2018 I thought the srubbies looked tougher and better able to survive the usage; but didn't know if the coarseness would be an asset or a detriment. Please update us on what you use and how it's working for you. Link to comment Share on other sites More sharing options...
bubba682 Posted April 5, 2018 Share Posted April 5, 2018 Miller makes a follower for there tig torch to use with titanium its pretty slick hope this helps by the look of the date im a little late . Link to comment Share on other sites More sharing options...
Please sign in to comment
